Shanling SM90 Network Player Adds HDMI ARC as Streamer Wars Heat Up Under $1,000
Shanling SM90 adds HDMI ARC, dual AKM DACs, and Android streaming under $1,000, but can it stand out in a crowded streamer market?
Shanling SM90 Music Streamer Angle
Shanling has officially unveiled the SM90, a compact network player that does more than just stream music. Priced just under $1,000, the SM90 integrates HDMI ARC, dual AKM DACs, and a modern Android-based platform into a single chassis designed to anchor both hi-fi and TV audio systems. That HDMI ARC input is the headline feature and not just for spec sheet bragging rights. It signals a shift in how companies like Shanling are positioning streamers in 2026: not as standalone music devices, but as central hubs for everything from Qobuz playlists to Netflix dialogue.
Although Shanling isn’t the first to build a capable streamer, the SM90 is among the first in its class to take HDMI ARC seriously. That single connection allows users to route TV audio directly into a two-channel system without needing an AVR or soundbar. It’s a practical move. More listeners are consolidating their systems, and the idea of separate music and TV setups feels increasingly outdated. The SM90 leans into that reality, even if purists might roll their eyes.
Familiar Hardware, More Focused Execution
Under the hood, Shanling sticks with a familiar and proven formula. Dual AKM AK4493S DACs handle conversion duties, paired with a closed Android 12 system running on a platform with 4GB of RAM and 64GB of internal storage. A 4.96-inch 1080p touchscreen anchors the user experience. Nothing here reinvents the category, but that seems intentional. Shanling appears more focused on stability and refinement than chasing novelty this time around.
shanling-sm90-rear-angle
Streaming support covers most of what buyers expect at this level. Qobuz Connect, TIDAL Connect, AirPlay 2, DLNA, and access to major streaming apps are all included, alongside Wi-Fi 6, Ethernet, and Bluetooth 5.2 with LDAC. Roon Ready status is still pending, which may give some buyers pause. In this segment, that box usually needs to be checked on day one.
Connectivity is where the SM90 starts to separate itself from a crowded field. In addition to HDMI ARC, it offers USB DAC functionality, optical and coaxial inputs and outputs, balanced XLR and single-ended RCA outputs, and support for internal storage via SSD. That’s a broader and more flexible I/O set than many competitors, reinforcing the idea that Shanling wants this to be the center of a system rather than just another endpoint.
The timing, however, is not exactly forgiving. The sub-$1,000 streamer category is now one of the most competitive in hi-fi, with strong options from WiiM, Eversolo, Cambridge Audio, and HiFi Rose already entrenched. Shanling’s approach leans more traditional, but with a modern twist in the form of HDMI ARC. Whether that combination is enough will come down to execution, particularly on the software side, where stability and responsiveness matter more than another feature checkbox.
The SM90 is less about breaking new ground and more about acknowledging where the category is headed. By adding HDMI ARC and expanding connectivity, it positions itself as a true system hub rather than just another streamer. What remains uncertain is how well it all works in the real world.
There are no meaningful third-party reviews yet, Roon certification is still pending, and Shanling’s software track record is not spotless. But if those pieces fall into place, the SM90 could land exactly where a lot of systems are heading—right between your speakers and your TV, whether audiophiles like it or not.
Features
  • Compact dimensions at 28 x 23 x 8.5 cm
  • Reduced weight at just 3.3kg
  • Dual AKM AK4493s DAC Section
  • OPA1612 Analog Output
  • 4.96-Inch 1080p Touch Screen
  • Closed Android 12 platform, Rockchip CPU
  • Qobuz Connect, Tidal Connect, Roon Ready (in process)
  • Built-in Streaming Apps
  • (Apple, Apple Classical, Amazon, Spotify, KKBox, Presto, Radio Paradise)
  • NAS, DLNA, AirPlay 2 Playback
  • Internal SSD Slot & USB Drive Playback
  • Bluetooth 5.2 Input support LDAC, AAC, SBC
  • Digital Inputs: Coaxial / Optical / USB DAC / HDMI ARC
  • Digital Outputs: Coaxial / Optical / USB
  • Analog Outputs: RCA & XLR
shanling-sm90-with-headphones
The Bottom Line
The Shanling SM90 is less about breaking new ground and more about acknowledging where the category is headed. By adding HDMI ARC and expanding connectivity, it positions itself as a true system hub rather than just another streamer, one clearly designed to sit between your TV and a modern two channel system without forcing you into an AVR or soundbar ecosystem.
What’s still missing is clarity where it matters. U.S. pricing appears to land somewhere around $900 to $1,000, but nothing feels fully locked, and that matters in a segment where even a modest price shift can change the conversation. There’s also no real world performance data yet, Roon certification remains pending, and Shanling’s software track record, while improving, has not been flawless. Past issues with app stability and gapless playback are still fresh enough to raise concern, and those are the kinds of problems that undermine an otherwise strong product.
It is also worth noting what is not here. There is no indication of built in room correction or system optimization tools, which feels like a missed opportunity in 2026, especially for buyers pairing a streamer with active speakers and expecting a more complete and flexible setup. At the same time, the competition is well established. WiiM, Cambridge Audio, Bluesound, Eversolo, and others already offer mature platforms, stable apps, and in some cases deeper ecosystem integration.
Shanling has been on a solid run lately with its higher end CD and SACD players and a steady stream of well received portable gear, so the SM90 is not arriving from a position of weakness. But this category does not reward potential, it rewards execution. If Shanling delivers stable software and consistent performance, the SM90 could be a serious contender. If not, it risks becoming just another well specified box in a segment that already has plenty of proven alternatives.
Where to buy: $969 (available April 2026)
2026 Grado Phono Cartridges
Grado updates its phono cartridge lineup with refined stylus, OCC copper coils, and improved designs across Lineage, Timbre, and Prestige series.
Clarus Concerto MKII Power Conditioner Angle Clarus Concerto MKII Power Conditioner Angle
Clarus Concerto MKII targets noise and power stability for high-end systems, but at $12,000 it raises the question: who really needs it?
SVS 3000 Micro R|Evolution Subwoofer Black Lifestyle SVS 3000 Micro R|Evolution Subwoofer Black Lifestyle
Can the SVS 3000 Micro R|Evolution deliver deep bass from dual 9-inch drivers, 1,200 watts power, and advanced DSP without taking over your room?
2026 Paradigm Premier v2 Loudspeakers 2026 Paradigm Premier v2 Loudspeakers
Paradigm Premier Series v2 arrives at AXPONA 2026 with six new models, upgraded driver technology, and pricing aimed at affordable high performance.
Advance Paris A-i190 Integrated Amplifier Black Advance Paris A-i190 Integrated Amplifier Black
Advance Paris debuts NOVA at AXPONA 2026 with modular integrated amplifiers, streaming and Bluetooth add-ons, but should streaming be optional at this price?
2026 Cambridge Audio MSX Speakers Lifestyle 2026 Cambridge Audio MSX Speakers Lifestyle
Cambridge Audio's MSX Series revives the Minx with compact modular speakers, BMR tech, and flexible sub options starting at $99.
Can the $259 Fosi Audio S3 streamer DAC and preamp challenge WiiM and Bluesound with balanced outputs and HDMI eARC despite missing key features?
Hi-Fi Components
Cambridge Audio adds a Black Edition to its CX Series, but is the CXN100 SE and new distribution the real story?
Does HDMI eARC support make the Cambridge Audio CXN100 SE a better $1,099 streamer for modern hi-fi systems?
Nagra Compact Player offers digital music streaming with DAC support up to PCM 384 kHz and DSD256. Is this the most attainable way into...
Can the iFi NEO Stream 3 and ZEN Stream 3 stand out in the crowded sub-$1,000 streamer market where WiiM, Bluesound, Eversolo, and Cambridge...
ONIX’s XMT20 streamer transport pairs a new Linux platform with Roon Ready, TIDAL and Qobuz Connect, plus high-end digital outputs and CD ripping support.
Can Roksan’s $4,500 Caspian 4G Streaming Preamp and $3,750 Power Amp compete with NAD and Naim in this price class?
Emotiva introduces an affordable line of fully balanced hi-fi separates for a discounted package price of $2,599.
