Sennheiser HD 500 BAM Mic Turns Audiophile Headphones Into ‘Tryhard Gaming Headsets’—Without the RGB Nonsense
Sennheiser HD 500 BAM adds a pro mic to 500 series headphones. No support for other brands, but max compatibility with PCs, consoles and mobile.
Sennheiser HD 505 BAMM Inline Boom Mic Accessory Add-on
Sennheiser is finally jumping into the gaming accessory arena with the new HD 500 BAM boom arm microphone, a long-overdue add-on that transforms the company’s beloved HD 500 series audiophile headphones into full-fledged gaming headsets. Surprising it took them this long—Audeze, Beyerdynamic, and even Meze Audio have been cashing in on the gaming crowd for years, and gamers spend billions annually on gear that blends high-fidelity sound with competitive advantage.
The HD 500 BAM plugs directly into the headphone’s cable port, bringing crystal-clear voice pickup to models like the HD 560S, HD 620S, and even legacy 5-8 and 5-9 series cans. Audiophiles no longer have to choose between pristine listening and precise comms—Sennheiser just turned its most popular headphones into a gaming powerhouse.
Gamers have long praised the comfort and immersive sound of our 500-series headphones, but the lack of a microphone meant compromise,” said Klaus Hanselmann, Audiophile Product Manager at Sennheiser. “The HD 500 BAM changes that—sleek, durable, and great-sounding, it levels up both input and output. It’s the perfect add-on for your daily driver headphones and a must-have accessory for anyone chasing a complete audio upgrade.”
sennheiser-hd-500-bam-with-headphone
HD 500 BAM Brings Pro-Level Voice Clarity and Gaming-Ready Features
At the core of the HD 500 BAM is a 10 mm electret condenser capsule with a cardioid pickup pattern—translation: your voice cuts through with clarity while background noise like PC fans, kitchen appliances, or your roommate’s endless snack rustling gets shut out. For gamers tired of juggling bulky headsets or running separate mics just to be heard, this add-on finally makes going from “audiophile listening only” to “full comms integration” painless.
The HD 500 series has always been a gamer favorite thanks to its spacious soundstage, natural imaging, and featherweight comfort—headphones that give you an edge when footsteps and directional cues matter. The BAM extends that advantage by handling both sides of the audio equation: hi-fi listening and clean, precise voice pickup. No extra stands, no interfaces, no Frankenstein setup—just plug in and go, whether you’re calling plays in a match or surviving another dreaded Monday Teams call.
sennheiser-hd-500-bam-boom-cable-kit
Sennheiser also made sure the HD 500 BAM plays nice with just about everything. It connects via a 4-pole 3.5 mm CTIA plug, has an in-line volume control with a mic mute switch, and ships with a trio of windscreens plus a Y-adapter for PCs with split mic/headphone jacks. At 1.5 meters (about 5 feet), the cable gives you enough slack without turning into a tangled mess—or catching on that Chipotle container that’s been grinding XP under your desk longer than you have.
HD 500 BAM Compatibility: Sennheiser Headphones, Consoles, and Devices That Play Nice
The HD 500 BAM isn’t some one-size-fits-all gimmick—it’s built specifically for Sennheiser’s own 500-series lineup. That means you’re in the clear if you’re rocking the HD 505 Copper or Gold, HD 550, HD 559, HD 560S, HD 569, HD 579, HD 599, HD 599 SE, or the newer HD 620S. Sorry, no dice with third-party brands—this one’s a Sennheiser-only party.
sennheiser-hd-500-bam-inline
On the source side, the BAM keeps things refreshingly versatile. PC gamers are covered on both Windows and macOS, and mobile users can hook in through USB-C to 3.5 mm adapters like Apple’s or Samsung’s official dongles (because of course we’re all living the adapter life in 2025). Console warriors aren’t left out either—Xbox controllers across Elite Series 1 & 2, the standard Xbox One revisions (1697, 1708), and the latest Series X pads all work seamlessly. Nintendo Switch players—whether you’re rocking the OG, Lite, or OLED—get full support too. And naturally, PlayStation DualSense controllers V1 through V5, plus the DualSense Edge and even the good old DualShock 4, are all onboard.
In short, unless you’re gaming on a toaster, Sennheiser’s got you covered.
sennheiser-hd-500-bam-gaming-lifestyle-male
The Bottom Line
The HD 500 BAM is a technically solid add-on that delivers clear, crisp voice capture thanks to its 10 mm electret condenser capsule and cardioid pickup pattern. Background noise—from PC fans to roommates yelling at their monitors—is effectively minimized, making it a real upgrade for gamers, streamers, and professionals alike. Its 1.5-meter cable, in-line volume/mute control, included windscreens, and Y-adapter for split PC jacks make setup straightforward, and compatibility across PCs, consoles, and mobile devices is impressive.
On the upside, it turns your HD 500 series headphones into a fully integrated gaming headset without needing extra stands, mics, or Frankenstein setups. The cardioid pattern ensures your voice comes through clearly in competitive matches, Teams calls, or late-night raids. Lightweight, sleek, and easy to attach, it maintains the comfort and immersive sound the HD 500 series is known for.
sennheiser-hd-500-bam-mic
The downsides? It’s Sennheiser-only, so if you’re rocking a favorite third-party headphone, tough luck. And while $59.95 USD / $79.95 CAD is reasonable, you’re paying extra for a relatively small boom mic rather than a full-fledged headset redesign.
Overall, the HD 500 BAM is a clever, practical solution for anyone who loves Sennheiser’s 500 series but has been waiting for a first-party voice solution.
Where to buy: $59.95 at Crutchfield
2026 Samsung Music Studio 7 Wireless Speakers Lifestyle
Samsung's Music Studio 7 and 5 Wi-Fi speakers debut with bold design, multi-room flexibility, and Atmos support, but can they challenge Sonos and Bluesound?
2026 Samsung HW-S990H Soundbar Lifestyle 2026 Samsung HW-S990H Soundbar Lifestyle
Samsung’s 2026 Q-Series soundbars build on Wireless Dolby Atmos, Q Symphony, and SpaceFit with options from full surround systems to all in one designs....
Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut Revel PerForma4 F346 Floorstanding Loudspeaker Grilles On and Off in Natural and Black Walnut
Revel Performa4 loudspeakers feature DCC drivers and an Acoustic Lens waveguide for both hi-fi and home theater systems with matching subwoofer and center channel.
Cayin N8iii DAP Angle Side Buttons Cayin N8iii DAP Angle Side Buttons
DAPs
Cayin N8iii launches at $3,999 with tube modes, AKM DAC, up to 1.285 watts of output, and a 13500mAh battery, but is it enough...
Samsung 2026 OLED TVs Samsung 2026 OLED TVs
Opening Day optimism, Sennheiser in limbo, Kaleidescape at 25, and a study that questions how we hear. Think you’re paying attention? Think again.
Headphones
Sennheiser’s consumer division is for sale again as Sonova exits. What happens next could reshape one of audio’s most recognizable brands.
Are wired IEMs making a comeback? CanJam NYC 2026 suggests growing demand as audiophiles chase better sound beyond wireless earbuds.
Sennheiser refreshes the CX 80U and HD 400U with USB-C digital audio, delivering reliable wired sound for modern phones, laptops, and everyday use.
Can the Sennheiser RS 275 finally fix late night TV listening and dialogue clarity without disturbing others through Auracast and low latency wireless audio?
ASUS ROG Kithara is a wired open-back planar gaming headset developed with HiFiMAN, prioritizing audiophile sound, wide soundstage, and precision over wireless convenience.
Audeze’s Maxwell 2 raises the bar for gaming headsets, featuring SLAM technology with improved sound, comfort, and a new control app.
Shopping for wireless noise cancelling over-ear headphones in 2025? Here are our picks for the best you can buy on any budget.
