Ruark’s MR1 Mk3 Desktop Speaker System Proves Size Isn’t Everything (But Sound Is)
Ruark MR1 Mk3 desktop speakers deliver high-res sound, versatile connectivity, and compact design. Add the RS1 subwoofer for deep bass without taking up space.
Ruark MR1 MK3 Desktop Speakers with iMac
If you care more about how your music sounds than ordering pad thai through your fridge, the Ruark MR1 Mk3 is speaking your language. It’s for people who don’t need a smart assistant yelling weather updates between tracks or an app just to change inputs. What you get instead is accuracy—real clarity, proper imaging, and enough low-end punch to make a sub optional (though the RS1 is there if you want to go deeper). It handles Bluetooth aptX HD, USB-C, optical, analog, and even vinyl through a proper phono stage—without trying to be your life coach.
No flashy touchscreen. No firmware circus. Just a compact, well-built speaker that connects to everything you actually use, short of your Balmuda toaster—but give it time. The MR1 Mk3 is what happens when a company focuses on sound first, and leaves the gimmicks for someone else’s Kickstarter.
From R1 to MR1: Consistent Class, Quiet Confidence
Our recent time with the Ruark R1 Bluetooth radio reminded us that some brands just get it. While the world chases gimmicks and garish LED lights, Ruark leans into timeless design and lets the sound do the talking. The R1 is the kind of tabletop radio that earns a permanent spot in your home—not because it’s shouting for attention, but because it delivers. Clear, articulate, surprisingly full sound from something barely bigger than a hardback book? That’s Ruark’s calling card.
ruark-mr1-mk3-with-tv
The MR1 Mk3 continues that same philosophy: form follows function, but never at the expense of style—or your wallet. This is a brand clearly focused on sound first, with industrial design that whispers good taste rather than screaming for validation. No flashy branding. No cheap materials. Just honest craftsmanship, careful engineering, and a price point that still feels rooted in reality.
Whether you’re upgrading your desktop setup, looking for proper stereo without turning your living room into a speaker showroom, or just want something that sounds expensive without requiring a second mortgage, the MR1 Mk3 fits the brief. It’s not trying to be a fashion accessory. It’s trying to be great.
Small Speakers, Zero Compromises: The MR1 Mk3 Delivers the Goods Without Hogging the Desk
Ruark didn’t just shrink the MR1 Mk3 to fit your shelf—they engineered it to shame anything else in its size class. Each speaker packs a 2.0-litre, bass-reflex cabinet that squeezes every last drop of performance from a custom 20mm silk dome tweeter and an 85mm natural fibre mid/bass driver. The result? A confident in-room frequency response from 50Hz to 22kHz that laughs in the face of cheap desktop plastic.
Powering all of this are twin 25W Class D amps—efficient, clean, and more than happy to rattle your desk without breaking a sweat. A 2.5kHz crossover keeps the signal tight and the imaging precise, while an onboard 24-bit/192kHz DAC ensures your digital sources are handled with audiophile-level care. This isn’t a lifestyle speaker pretending to be hi-fi—it’s a hi-fi system that happens to fit next to your laptop.
On the connection front, it’s ready for almost anything short of carrier pigeons. Bluetooth 5.1 handles wireless duties with support for aptX HD, aptX, AAC, SBC, BLE, and A2DP—so whether you’re streaming from an Android, iPhone, or something in between, your music won’t sound like it’s coming through a wet sock. USB-C input (24-bit/96kHz) adds plug-and-play convenience for laptops, tablets, and modern smartphones, ensuring high-resolution playback without the driver drama.
Vinyl lover? There’s a proper moving magnet phono stage built-in—no cheap add-ons or external boxes required. You also get an optical input (TOSLINK, up to 24-bit/192kHz), an aux combo jack, and a dedicated mono RCA sub out if you want to add a little extra low-end muscle.
ruark-mr1-mk3-front-back
And because this thing is as smart as it is small, there are thoughtful touches like auto-standby (snooze mode), adjustable input levels for all sources, and a remote that won’t send you digging through a drawer every time you want to skip a track.
The MR1 Mk3 comes in two finishes—rich walnut veneer or sleek charcoal lacquer—each paired with a dark slate woven fabric grille that actually feels as good as it looks. At just 4.85 lbs per speaker and modest in size (7.95″ H x 5.31″ x 6.5″ D), this isn’t just about saving space—it’s about owning that space with authority.
In the box?
  • Left and right speakers
  • 3m high-purity speaker link cable
  • AC power adapter
  • Remote with battery
  • Quick start guide (for those who don’t believe in manuals)
Add Depth Without Taking Up Space: The RS1 Subwoofer
For listeners who want a bit more low-end authority without sacrificing room aesthetics or square footage, the Ruark RS1 Subwoofer is a smart, compact solution. Designed to pair seamlessly with the MR1 Mk3, R3S, R410—or any active speaker or amplifier with a sub-out—the RS1 offers refined bass extension in a form factor that’s easy to tuck under a desk or next to a media console.
ruark-mr1-mk3-rs1
Housed in a tuned passive radiator enclosure, the RS1 combines a 170mm long-throw active driver with a 170mm passive radiator, powered by a 100W Class D amplifier. With a frequency response of 25Hz to 200Hz, it adds depth and weight to music and movie soundtracks without sounding bloated or overpowering.
It includes user-friendly features like an adjustable crossover (50–180Hz)input/volume control, and a 180° phase switch, allowing for better integration with a variety of speaker setups. The auto-on function ensures the subwoofer wakes when it receives signal and enters standby after 15 minutes of inactivity—convenient for everyday use.
Available in Rich Walnut or Satin Charcoal lacquer finishes with a slate grey cloth grille, the RS1 blends easily into most home environments.
Key Specifications:
  • Frequency Response: 25Hz – 200Hz
  • Amplifier: 100W RMS Class D with soft clipping
  • Drivers: 170mm treated fibre active driver + 170mm passive radiator
  • Enclosure: Tuned passive radiator cabinet
  • Controls: Crossover (50–180Hz), level, phase switch
  • Input: Mono RCA (up to 2.3Vrms)
  • Auto Mode: 15-minute auto-standby
  • Power Consumption: 0.5W standby, 2.0W idle
  • AC Power Input: 100–240V, 50–60Hz
  • Dimensions (including feet and controls):
    • Height: 300mm / 11.81 inches
    • Width: 250mm / 9.84 inches
    • Depth: 265mm / 10.43 inches
    • Weight: 6.7kg / 14.77 lbs
  • What’s Included:
    • RS1 Subwoofer
    • AC mains lead
    • 1.5m RCA connector cable
    • Quick start guide
The Ruark MR1 Mk3 and RS1 subwoofer are proof you don’t need to sacrifice sound quality just to save space—these compact units pack serious technical muscle. Crisp 2-way bass-reflex speakers with 25W Class D amps and a 24-bit/192kHz DAC deliver detailed, punchy audio from a footprint smaller than your lunchbox.
Add the RS1’s 100W Class D-powered passive radiator sub, and you get deep bass extension that won’t hog your floor or embarrass your living room. Together, they offer flexible, high-res connectivity and smart controls without the usual desktop clutter or price tag that demands a small loan. In other words, Ruark’s engineered a tidy little package that sounds way bigger than it looks—and that’s no accident.
ruark-mr1-mk3-walnut-with-imac
The Bottom Line
Available mid-July 2025, the Ruark MR1 Mk3 delivers high-resolution sound, true vinyl compatibility with a built-in MM phono stage, USB-C and Bluetooth 5.1 with aptX HD support, all in a compact, beautifully designed desktop speaker system. Perfect for music lovers who want premium audio without the clutter, gimmicks, or needless complexity.
Ruark’s new MR1 MK3 desktop speakers are priced at $579 USD, £399 GBP, and €479 EUR.
For more information: ruarkaudio.com
4 Comments
4 Comments
  1. Larry
    June 7, 2025 at 2:11 pm
    Hi Ian,
    Following up on our exchange on the Pro-Jects, these look like a home run. While I agree with your target market observations, especially concerning how people will store and transport them, the lack of a digital interface (for me) limits their usefulness for video.
    I’m curious to know if you’ve heard them. If they sound as good as they look, they should be a success.
    Larry
    • Ian White
      June 7, 2025 at 10:48 pm
      Larry,
      I’m doing a trilogy of Ruark reviews. R1 was first. The R410 is next. The MR1 Mk3 will be in August. I also hope to do the R610 and R810 Console in September or October.
      IW
      • Anton
        June 10, 2025 at 11:23 am
        How do you think these will compare to the R1 you just reviewed?
        The mid-century look is very appealing although that “roto” dial looks somewhat weird on top.
        • Ian White
          June 10, 2025 at 9:03 pm
          Anton,
          You’ve been busy today on our site. Must be nice to not have to work. Having not heard them yet, I really can’t comment on their performance, but I suspect they are not as polite sounding as the R1 and can definitely play a lot lower in the bass range and will provide a wider soundstage.
          IW
Edifier M90 Wireless Speakers Lifestyle Gaming in White
Edifier’s M90 is a "cross-scenario, multi-purpose" active speaker, performing equally well in TV and home entertainment setups as well as in PC, desktop, and...
Sylvox Cinema Pro 110-inch Helio QLED Outdoor TV by pool Sylvox Cinema Pro 110-inch Helio QLED Outdoor TV by pool
Sylvox debuts the world’s first frameless outdoor TV at CES 2026, plus a 110-inch 4K QLED model built to survive sun, rain, sports nights,...
Brane Party Pro Portable Speaker at CES 2026 Brane Party Pro Portable Speaker at CES 2026
Brane Audio debuts RAD2 at CES 2026, previewing the Party Pro prototype and a radical new approach to deep bass that could reshape portable...
Audio-Technica AT-LP7X Turntable Audio-Technica AT-LP7X Turntable
Audio-Technica’s AT-LP7X is a $999 fully manual belt-drive turntable with precise speed control, adjustable tonearm geometry, and built-in MM/MC phono support.
Onkyo Muse Y50 Streaming Amplifier Black Angle Onkyo Muse Y50 Streaming Amplifier Black Angle
Onkyo marks its 80th anniversary with the Muse Y-40 and Y-50—compact streaming integrated amps with AirPlay 2, MM/MC phono, and HDMI ARC.
Klipsch The Nines II Wireless Power Speakers Lifestyle Klipsch The Nines II Wireless Power Speakers Lifestyle
Klipsch marks its 80th anniversary with the Fives II, Sevens II, and Nines II—more power, refined drivers, Onkyo electronics, Dirac Live, and immersive audio...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
The Tivoli SongBook MAX is retro, loud, and weirdly addictive. Mid-century design meets Miami volume—your neighbors may never forgive you.
Our favorite streaming amplifiers of 2025 for audiophiles include models from WiiM, Marantz, Ruark, Naim and Aavik.
This is the really good stuff for audiophiles, music lovers and home theater enthusiasts that's guaranteed to impress.
Audioengine expands into Nordstrom, Best Buy, and Crosley, bringing its handcrafted hi-fi speakers to major retail shelves and new audiences nationwide.
Ruark R1 vs Tivoli Model One BT: a showdown of design, tone, and tech. Tivoli brings punch, but the Ruark’s refinement makes it worth...
The Ruark R1 is a Bluetooth/FM radio that actually sounds good, looks like it belongs, and won’t land you in jail. Hi-fi snobs, meet...
Ruark’s R610 compact music console delivers punch and clarity, though speaker matching is crucial to unlock its full potential.
