In a category where the AirPods Pro and Sony’s latest noise-canceling darlings eat up all the oxygen—and most of the market share—boutique brands like Noble Audio don’t get to play it safe. If you’re asking consumers to part with nearly $400 for a pair of true wireless earbuds, you better bring more than just decent ANC and a splashy app. Noble’s answer? The new FoKus Amadeus, a bold, crimson-clad shot across the bow that blends Mozart-level finesse with bleeding-edge tech like LDAC, Bluetooth 5.4, and Audiodo Personal Sound.
With up to 42 hours of battery life and a design that actually makes a statement, the Amadeus isn’t here to blend in—it’s here to remind you that hi-fi can still be wearable and weirdly wonderful.
A Triple-Layer Driver That Doesn’t Phone It In—FoKus Amadeus Brings the Drama, Not Just the Specs
Under the bold exterior, the FoKus Amadeus hides a new 8.3mm custom dynamic driver with a triple-layer diaphragm—because apparently two layers just wouldn’t cut it. The result? Bass with actual weight, mids that feel open rather than boxed in, and treble that extends without stabbing you in the eardrum. It’s a tuning that leans expressive and detailed without going full lab coat.
There’s space, warmth, and just enough bite to keep things interesting whether you’re dissecting a string quartet or zoning out to your latest playlist. Noble clearly voiced this one for balance—not too sterile, not too syrupy—just the kind of engaging sound that keeps you listening longer than you planned.
Audiodo Personal Sound: Because Your Ears Aren’t Clones
After the strong reception of the FoKus Rex5, Noble has once again teamed up with Audiodo to bake in its Personal Sound tech—essentially a hearing test that doesn’t suck. The system analyzes each ear independently and creates a custom sound profile that lives inside the earbuds, not just in the app. That means once it’s set, it stays set, no matter what device you’re paired to.
For anyone with subtle (or not-so-subtle) differences between ears—and let’s be honest, that’s most of us—Audiodo unlocks more clarity, detail, and balance. Whether it’s background percussion or the tonal edge of a piano, the result feels more dialed-in and immersive, like the sound is adjusting to you instead of the other way around.
Bluetooth 5.4 and a Brainy Chipset—Because Lag Is So Last Season
Powered by Qualcomm’s QCC3091 and running the latest Bluetooth 5.4, the FoKus Amadeus isn’t messing around when it comes to wireless performance. Whether you’re streaming in LDAC, aptX Adaptive, or just slumming it with AAC or SBC, audio stays high-res and low-lag. You also get TrueWireless Mirroring for smoother connections and multipoint pairing—so you can jump between your phone and laptop without rage-quitting Zoom. Touch controls are onboard (because buttons are apparently too 2022), and dual mics with cVc noise cancelling keep your voice clear even when you’re yelling into the wind or dealing with the acoustic hellscape of a coffee shop.
Battery Life That Actually Keeps Up With You
With ANC off, you get up to 12 hours per charge; flip ANC on and it drops to 8—not groundbreaking, but solid. The case gives you another 2.5 charges, topping out at a respectable 42 hours total. USB-C and Qi wireless charging are both in play, and a 10-minute quick charge gives you around two hours of listening—just enough to get through your commute or that endless meeting that should’ve been an email. The fit is snug, the power management is smart, and the whole setup is clearly designed for daily grind survival, not just Sunday morning listening sessions.
Key Specifications – FoKus Amadeus
- Driver: 8.3mm custom triple-layer dynamic diaphragm
- Frequency Response: 20Hz – 20kHz
- Sensitivity: 113 ± 2dB @ 1kHz
- Impedance: 37 Ohm
- Output Power: 3mW
- Chipset: Qualcomm QCC3091
- Bluetooth Version: 5.4
- Supported Codecs: SBC, AAC, aptX Adaptive, LDAC
- Earbuds Battery: 65mAh
- Charging Case Battery: 500mAh
- Playback Time:
- Up to 12 hours (ANC off)
- Up to 8 hours (ANC on)
- Up to 42 hours total with case
- Charging Time:
- 90 minutes (earbuds)
- 120 minutes (case)
- Quick Charge: 10 minutes = ~2 hours playback
- Charging Options: USB-C & Qi wireless charging
- Microphones: Dual mics with cVc noise cancelling
- Noise Control: Active Noise Cancellation + Transparency Mode
- Multi-point Bluetooth connection
- TrueWireless Mirroring
- Auto Power On/Off
The Bottom Line
The Noble FoKus Amadeus strikes a rare balance between cutting-edge tech—like Bluetooth 5.4, LDAC support, and Audiodo Personal Sound—and a design that actually stands out in a sea of cookie-cutter earbuds. With solid battery life, premium features, and a price tag hovering well below $400, it offers serious value for anyone tired of sacrificing style or sound for affordability. If you want true wireless earbuds that deliver both personality and performance without demanding a Mozart-sized budget, the Amadeus is playing your tune loud and clear.
Price & Availability
The Noble FoKus Amadeus will be available for preorder starting June 11, 2025, with shipping to begin on June 18, 2025. You can grab a pair from nobleaudio.com or selected retailers worldwide for $320 USD, £299 GBP, or €349 EUR. Premium sound with a splash of classical flair doesn’t come cheap—but then again, neither does Mozart’s legacy.
Where to buy:
Related Reading:
- Noble Audio’s FoKus Rex5 Wireless ANC Earbuds Feature Audiodo Sound Personalization
- Noble Audio’s FoKus Triumph Wireless Earbuds Incorporate XMEMS Technology
- Astell&Kern LUNA IEMs Land At $2,700: Because Sonic Purity Apparently Comes With A Quirky Low Impedance
- Sony LinkBuds Open Review: More Affordable Than Apple And Bose Wireless Earbuds
