NAD M33 V2 & M23 V2 Crash High End Munich: Canadian Hi-Fi Invades, Apologizes, Then Sounds Better Anyway
NAD’s M33 V2 and M23 V2: No bling, no hype, just solid sound and engineering that actually matters with support for MQA FOQUS and QRONO.
NAD M33 V2 BluOS Streaming Amplifier and M23 V2 Stereo Power Amplifier
NAD Electronics just reminded everyone at High End Munich that when it comes to high-performance audio, Canada still knows how to play with the big kids — and occasionally humble them with a smile and a “no doubt.” The NAD M33 V2 BluOS Streaming Amplifier and M23 V2 Stereo Power Amplifier aren’t just refreshes — they’re the underpaid third-liners that skate hard, hit clean, and still bury the puck top shelf when it counts. Updated digital architecture. Cleaner, more refined sound. And the kind of connectivity that makes you wonder why everyone else overcomplicates the obvious.
For the audiophiles, integrators, and premium dealers still sleeping on NAD’s relevance in 2025 — wake up. These aren’t nostalgia plays. They’re a reminder that NAD’s been doing smart, no-BS hi-fi longer than most brands at this show have been alive. And while Munich might be the playground of champagne-priced gear with Rolex attitude, NAD just walked in wearing flannel and Kodiaks, and still got more attention.
M33 V2: Reference-Level Streaming
nad-m33-v2-lifestyle-angle-left
NAD’s M33 was released in 2020 and earned accolades by doing what most streaming amps couldn’t: sounding like real hi-fi while quietly running circles around the feature-choked competition. The M33 V2 doesn’t show up with flash or ego — just better parts, smarter thinking, and the kind of obsessive detail work that makes a difference once you actually sit down and listen. No gold plating, no glowing tubes. Just serious engineering and a chassis that feels like it was designed to outlive your rack.
This time around, NAD drops in MQA Labs’ new FOQUS and QRONO tech — fancy acronyms that still need to prove themselves–we’re still not really over the MQA TIDAL fiasco but time heals old wounds and apparently Canadians are all about forgiveness–even though none of us who suffered through Trudeau can understand pressing “repeat”–but time to move on.
Pair that with an ESS SABRE ES9039PRO DAC, a next-gen ESS ADC, and Purifi’s updated Eigentakt modules, and you’ve got a signal path so clean and tight it could moonlight as a Swiss watch. Except this one’s designed in Canada, so it’s probably more like a G-Shock with the fancy snow cover and anti-scratch guard.
Cas Oostvogel, NAD’s Product Manager, puts it best: “We’re not just chasing distortion numbers — we’re addressing how your brain actually processes sound timing.” Translation? The M33 V2 isn’t just more accurate on paper. It sounds more human–which may or may not be a good thing depending on your choice of music.
nad-m33-v2-rear
Key Upgrades (that actually mean something):
  • FOQUS (ADC) + QRONO (DAC) from MQA Labs: It’s all about timing. Not the kind that sells on a spec sheet — the kind that makes your shoulders drop when the music locks in.
  • ESS ES9039PRO DAC: NAD’s never chased audiophile jewelry, but this DAC brings real heat — more detail, less glare, better flow.
  • Dirac Live Bass Control-ready: Because subwoofers shouldn’t feel like guesswork.
  • XLR pre-outs and a proper sub output: Real flexibility for folks running separates or dual subs without relying on voodoo or adapters.
And then there’s the stuff that just works: BluOS for multi-room streaming that doesn’t require a PhD, Apple AirPlay 2, aptX HD Bluetooth, HDMI eARC, and compatibility with every smart home platform you’ve ever heard of (and a few you haven’t). The M33 V2 slots into just about any system without asking you to ditch what you already like — a rare trait in this price bracket.
It’s a reference-level amp that doesn’t scream for attention — just builds it, detail by detail. Classic NAD. Canadian through and through from the outskirts of the traffic train wreck known as Toronto.
M23 V2: Power with Precision, No Drama…But a Little Would be Fine
nad-m23-v2-angle
NAD M23 V2 Stereo Power Amplifier
The original NAD M23 earned its reputation the old-fashioned way: clean power, solid engineering, and none of the usual audiophile nonsense. The NAD M23 V2 takes that same workhorse mentality and tightens it up with updated Eigentakt modules from Purifi, a few practical upgrades, and the kind of measured refinement you only get from people who care more about circuit stability than champagne-finished faceplates.
Rated at 200-watts per channel into 8 ohms (and a ridiculous 700W bridged), the M23 V2 isn’t here to show off — it’s here to deliver. Whether you’re pairing it with the M33 V2, the M66 preamp, or using it to add serious headroom to your system, this thing just does the job — clean, quiet, and without shutting down with your Maggies.
nad-m23-v2-rear
What’s New (and Actually Useful):
  • Updated Purifi Eigentakt Modules – Less distortion, better timing, and still one of the most neutral-sounding Class D implementations out there.
  • 12V Trigger with Timed Delay – Smart little feature that makes multi-amp setups easier and saves your breakers from getting slammed.
  • Balanced XLR + RCA Inputs – NAD didn’t cut corners here. It’ll play nice with just about anything.
  • Bridgeable – Need more juice? Flip the switch and double your output. No drama.
The M23 V2 doesn’t color the music or try to impress you with bells and whistles. It just delivers effortless dynamic power and transparency — the kind that lets the rest of your gear and your recordings do the talking. And it does that without turning into a space heater or making you second-guess your speaker cables.
System Synergy, NAD Style
Run the M33 V2 and M23 V2 together and you’ve got a fully modern, fully balanced system that sidesteps the boutique markup but keeps the performance right where it should be. This is NAD’s Masters Series philosophy in action: intelligent engineering, understated design, and performance that speaks for itself. No rose gold, no exotic wood, no inflated egos.
nad-m33-v2-and-m23-v2-lifestyle-left
The Bottom Line
Both the M33 V2 and M23 V2 share NAD’s clean, purposeful industrial design — solid aluminum casework, magnetic iso-point feet, and not a fingerprint-magnet in sight. The M33 V2 and M23 V2 are built like proper Canadian gear — Just clean lines and zero design drama.
You unbox it, think “that’s sharp”, rack it up, and forget about it — until the music hits and reminds you why you didn’t blow the budget on billet knobs and champagne finishes.
NAD’s not out here trying to win a fashion show. They’re building gear that gets out of the way and lets the music do what it’s supposed to. No fluff, no filler, just proper hi-fi that doesn’t need to peacock to prove it belongs.
Pricing & Availability
Both new products are expected to be available August 11, 2025 at the following prices:
  • NAD M33 V2 – USD $5,999 (GBP £4,999 / EUR €6,499)
  • NAD M23 V2 – USD $3,999 (GBP £3,499 / EUR €4,499)
The original M33 ($6,499 at Crutchfield) and M23 ($4,799 at Crutchfield) currently cost more, but were announced for much less.
NAD product pages: M23 V2 | M33 V2
2 Comments
2 Comments
  1. Anton
    May 14, 2025 at 8:15 pm
    That M33 V2 is very appealing. And it looks like it means business.
    I like the build quality of NAD gear. Reliable and sturdy.
    The new MQA stuff raises an eyebrow.
    • Ian White
      May 15, 2025 at 1:34 am
      Yes, the M33 V2 is a very comprehensive piece of gear that does it all. It’s also modular which keeps it current. There are two card slots in the back. NAD’s Master Series is very good. And it’s built very well.
      I have no idea what any of the new MQA technology does and I hope one can turn it off if it doesn’t really impress. I never liked MQA as part of TIDAL, so I’ll need some convincing.
      IW
Q Acoustics Easyfit In-ceiling Speakers Lifestyle
In-Ceiling Speakers
Q Acoustics Easyfit in-ceiling speakers feature tool free spring mounting, pivoting tweeters, IPX4 rated models, and proven driver tech for Atmos and whole home...
Astell&Kern PD20 DAP Front and Back Angle Views Astell&Kern PD20 DAP Front and Back Angle Views
DAPs
Can the Astell&Kern PD20 redefine portable hi-fi with hearing based personalization and Triple AMP architecture for under $2000?
Technics SL-1500CS Turntable Silver Technics SL-1500CS Turntable Silver
Technics SL-1500CS upgrades the popular SL-1500C with Delta Sigma Drive motor control. Does this precision boost make it the new direct drive leader in...
Rega Aos MC Phono Preamplifier Angle Left Rega Aos MC Phono Preamplifier Angle Left
Rega's Aos MC borrows from the company’s $7000 reference phono stage at around $2300. Is it the new sweet spot for serious MC vinyl...
Nagra Compact Player Angle Nagra Compact Player Angle
Nagra Compact Player offers digital music streaming with DAC support up to PCM 384 kHz and DSD256. Is this the most attainable way into...
LG xboom Plus and Lite wireless earbuds LG xboom Plus and Lite wireless earbuds
LG expands its xboom lineup with Buds Plus and Buds Lite, adding ANC, Auracast, UVnano+ tech, and up to 35 hours of battery life.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Is the Aavik M-880 pure excess, or a serious rethink of Class A amplification delivering 400 watts at $115,000 per channel?
Burmester’s new Reference Line arrives with engineering so precise it practically orders its own beer, along with a price tag that's enough to buy...
Unison Research’s Unico PRE v2 and DM v2 introduce a modern design, substantially more power, and an $18,498 system price—no streamer, no Bluetooth, just...
Esoteric’s N-05XE and S-05XE combine flagship DAC, streaming, balanced preamp, serious headphone amp, and Class A power—but at $26,500, is this the most future-proof...
ARCAM’s new Radia home theater lineup adds Dirac Live ART, higher channel counts, and new audio video amps and processors, priced from $4,500 to...
Can Roksan’s $4,500 Caspian 4G Streaming Preamp and $3,750 Power Amp compete with NAD and Naim in this price class?
Emotiva introduces an affordable line of fully balanced hi-fi separates for a discounted package price of $2,599.
Dan D’Agostino’s Momentum Z Monoblock pushes the Momentum platform forward with regulated power delivery, revised circuitry, extreme output—and a price that firmly places it...
