L-Acoustics to Showcase HYRISS at CEDIA 2025: Where Architectural Design Meets Cutting-Edge Spatial Audio
L-Acoustics showcases its new HYRISS immersive audio system at CEDIA 2025, blending spatial sound with architectural design for high-end residential and yacht AV installs.
L-Acoustics Hyriss Audio Rack
L-Acoustics may be best known for powering massive venues like the Hollywood Bowl and Adele’s epic concert in Griffith Park, but the French pro audio heavyweight isn’t just for stadiums and festivals anymore. At CEDIA Expo 2025, they’re bringing their world-class audio expertise to the high-end residential and marine markets—because why shouldn’t your living room or yacht sound like a front-row seat?
This year’s spotlight is on HYRISS (Hyperreal Immersive Sound Space), L-Acoustics’ latest push into the realm of spatial audio and architectural integration. Designed to blur the lines between performance-grade tech and immersive home audio, HYRISS showcases just how far the company can push the envelope when it comes to custom install applications. Whether it’s a home theater, luxury condo, or something that floats, L-Acoustics wants every space to sound like the main stage.
L-Acoustics isn’t showing up to CEDIA 2025 with just another pretty speaker. The HYRISS demo is built to showcase how serious pro-grade audio can be integrated into residential and marine spaces without compromising fidelity—or your interior design.
HYRISS blends architectural sensibility with spatial audio tech in a way that feels more refined than revolutionary. The system adapts to different environments with the kind of precision you’d expect from the folks who outfit the Hollywood Bowl—but now it’s for your personal wine cellar or 90-foot yacht. Installers get a toolkit that’s flexible, scalable, and unapologetically French in its insistence that form and function can—and should—coexist.
l-acoustics-x6i-x8i
L-Acoustics X6i and X8i speakers are designed for height channels
The HYRISS demo will feature a mix of L-Acoustics Soka loudspeakers and SB10i subwoofers handling the surround channels, with X4i models taking care of the height channels. It’s a compact but powerful configuration, creating a full 360-degree spherical audio field that doesn’t require massive enclosures or compromises on placement.
At the center of it all is Anima—the spatialization engine built into the L-ISA processor. Rather than relying on traditional channel mapping, Anima Signatures convert conventional audio into a multidimensional sound experience. For integrators, it offers a new way of designing immersive systems—one that moves beyond channel counts and starts thinking in terms of fluid, location-aware sound. It’s less “throw more speakers at it” and more “let the system do the heavy lifting.” Very French. Very clever.
l-acoustics-soka-colors
The L-Acoustics demo system will be powered by LA7.16i amplified controllers—robust, install-friendly amps designed for serious output and fine control.
Source components include Kaleidescape’s high-resolution media servers and StormAudio processors, feeding digital signals through the LC16D converter. This unit translates AES/EBU and MADI into Milan-AVB protocol, all packed into a durable 1RU chassis built with installation flexibility in mind.
An LS10 Milan-AVB switch ties the entire ecosystem together, ensuring seamless integration and efficient signal routing. On the visual side, the experience will be enhanced by projection and processing solutions from Barco Residential and madVR, while Stewart Filmscreen provides an acoustically transparent screen to let the L-Acoustics speakers perform without obstruction—meeting the SPL and clarity benchmarks of the CEDIA RP22 standard.
For integrators and designers, L-Acoustics will also showcase Soundvision Connect—its cloud-based extension of the long-standing Soundvision 3D modeling software. The platform streamlines system design and makes collaboration with clients, architects, and consultants easier, presenting detailed acoustic plans in an interactive 3D format. It’s high-end modeling without the headache, and another example of the brand’s commitment to precision from sketchpad to installation.
From  Nick Fichte, Global Business Development Lead, Home & Yacht at L-Acoustics: “We’re excited to welcome CEDIA Expo visitors into our immersive demo space to experience the power and adaptability of HYRISS technologies firsthand,….L-Acoustics lives and breathes innovation, and our technologies unveiled at CEDIA Expo will mark a major step forward in professional-grade audio for luxury residences and yachts. With our trusted products, expert support, and integrator-first approach, L-Acoustics continues to rewrite the rules for what’s possible in home and marine audio.”
Outside of the main demo space, L-Acoustics will also host a secondary booth area where visitors can get hands-on with individual loudspeakers and components from across the lineup.
This includes a closer look at the new LA1.16i amplified controller—a more compact sibling to the LA7.16i—designed for installations where space, efficiency, and performance need to coexist without compromise. It’s a chance for integrators to see how L-Acoustics’ technologies scale across different system sizes and applications without losing their edge.
l-acoustics-lai.16i
L-Acoustics LA1.16i amplified controller
The Bottom Line
If the 2024 exhibit was any sign of things to come, L-Acoustics is about to raise the bar—again. The HYRISS system promises to go beyond traditional immersive formats like Dolby Atmos or DTS:X with a more adaptive approach, but that opens up a lot of questions: How exactly does HYRISS differ in its spatial mapping? Is it scalable without compromise? Will it work as intended outside of a carefully controlled demo room?
And perhaps the most important question for integrators and clients alike—what’s the price of entry for this level of spatial precision and performance? Given the pedigree and hardware involved, it won’t be cheap. We’ll reserve judgment until we hear it in action—but you can bet we’ll be listening closely.
For more information: l-acoustics.com
JLab Blue XL Wireless Headphones and Speakers
Esoteric N-05XE DAC Preamplifier Streamer and S-05XE Power Amplifier Esoteric N-05XE DAC Preamplifier Streamer and S-05XE Power Amplifier
Esoteric’s N-05XE and S-05XE combine flagship DAC, streaming, balanced preamp, serious headphone amp, and Class A power—but at $26,500, is this the most future-proof...
Bowers & Wilkins 707 Prestige Edition Speakers Pair in Santos Gloss Front Bowers & Wilkins 707 Prestige Edition Speakers Pair in Santos Gloss Front
For about a 10% price premium, customers in the EU and APAC can purchase the Bowers & Wilkins 707 Prestige Edition bookshelf speaker in...
2026 ARCAM Radia AVA 2026 ARCAM Radia AVA
ARCAM’s new Radia home theater lineup adds Dirac Live ART, higher channel counts, and new audio video amps and processors, priced from $4,500 to...
Theory Professional SR-221.3 Sound Reinforcement Loudspeaker - Think Outside The Box at ISE 2026 Theory Professional SR-221.3 Sound Reinforcement Loudspeaker - Think Outside The Box at ISE 2026
Theory Professional previews the SR-221.3 at ISE 2026, an extreme-output full-range loudspeaker. Pricing isn’t final, but it won’t be cheap.
JBL Synthesis SCL In-room Loudspeakers 2026 JBL Synthesis SCL In-room Loudspeakers 2026
JBL Synthesis rolls out 4 new in-wall speakers, 4 in-room speakers, 2 AV preamps, 1 AVR and 1 subwoofer. Is this the cleanest system-level...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Forget sound bars and souped up TV speakers, a real Dolby Atmos immersive surround sound system is more affordable than you might think.
Daily Deals
Why bother with under-performing soundbar-based surround sound systems when you can pick up this separates-based complete home theater for under $1,200?
Focal quietly drops the $699–$2,299 Omada speakers between Vestia and Theva, packing TAM tweeters and Slatefiber cones in a non-typical rollout but with good...
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Your ticket to watching movies on a Kaleidescape 4K movie server just got a $1,000 cheaper, but are the trade-offs worth the discount?
After three days roaming the hallowed halls of CEDIA Expo 2025, here are our picks for "Best in Show" for home theater systems.
From media players to video processors, giant TVs and auto-masking screens, here are our picks for best video products at CEDIA Expo 2025.
CEDIA Expo 2025 featured many fine speakers, amps, processors and other audio-related gear. Here are our picks for Best in Show.
