Hi-Fi Components
Cambridge Audio CX Series Gets Black Edition Finish, No Changes Under the Hood
Cambridge Audio adds a Black Edition to its CX Series, but is the CXN100 SE and new distribution the real story?
Cambridge Audio CX Series Hi-Fi Components in Black Stacked
Cambridge Audio is giving its CX Series a darker look, but the bigger story sits behind the rack. The UK-based brand has introduced Black Edition versions of the CXA81 Mk II integrated amplifier and CXC CD transport, alongside the new CXN100 SE network streamer, which is the only actual addition to the lineup. All three arrive in a refined matte black finish, with no changes to the core circuitry or performance compared to the standard Lunar Grey models.
What matters more, however, is where Cambridge Audio is headed in North America. Distribution has shifted to Fidelity Imports in the U.S. and True North Distribution in Canada (a new joint venture with Playback Distribution), a move that could have far greater impact on availability, dealer support, and long-term brand visibility than a fresh coat of paint. The hardware may look different, but the strategy behind it is doing the real work.
CXA81 MKII Integrated Amplifier
cambridge-cxa81mk2-black-front-back
The anchor of Cambridge Audio’s CX range, the CXA81 Mk II, released in 2024, is an integrated amplifier rated at 80 watts per channel. It’s designed to deliver a clean, controlled presentation across both digital and analog sources, whether you’re streaming high resolution audio or spinning vinyl through an external phono stage.
The CXA81 Mk II balances output and refinement with the neutral, open character the CX Series is known for, making it a flexible centerpiece for a wide range of two channel systems without leaning too warm or overly analytical.
CXA81 MK II Feature Highlights
  • Amplifier Type: Class A/B design for a balance of efficiency and linear performance
  • Power Output: 80 watts per channel, providing sufficient current for a wide range of loudspeakers
  • DAC: ESS ES9018K2M SABRE32 for high-resolution digital-to-analog conversion
  • Digital Inputs: TOSLINK (optical), coaxial, and USB Audio
  • Analog Inputs: Single-ended RCA and balanced XLR connections
  • Bluetooth: Version 4.2 with A2DP/AVRCP support, including aptX HD (up to 24-bit/48 kHz)
To dig deeper into the CXA81 MK II refer to our companion article. Cambridge Audio’s CXA81 MKII Integrated Amplifier
CXC CD Transport
cambridge-cxc-black-front-back
The current version of the CXC was released in 2023. It’s designed for listeners who still value their CD collections and want to extract the best possible performance from those 5-inch discs. By focusing strictly on digital transport duties, Cambridge Audio has stripped away anything that doesn’t serve accurate data retrieval and timing.
The result is a purpose-built CD transport engineered for precise disc reading and low-jitter digital output, delivering a cleaner, more consistent signal to an external DAC without unnecessary processing getting in the way.
CXC Feature Highlights
  • Custom S3 Servo Drive: Designed for accurate disc tracking and data retrieval with reduced read errors.
  • Disc Compatibility: Supports Red Book CD (CD-DA), CD-R, and CD-RW formats.
  • Digital Outputs: Includes both coaxial and optical outputs for connection to an external DAC.
  • Gapless Playback: Enables seamless transitions between tracks, ideal for live recordings and continuous mixes without added silence.
  • Acoustically Dampened Chassis: Helps reduce vibration and isolate internal components for more consistent performance.
To dig deeper into the CXC CD Transport, refer to the official Cambridge Audio CXC product page.
CXN100 SE Network Streamer
cambridge-cxn100se-black-front-back
Completing the system is the new CXN100 SE, available in both the matching Limited Edition Black finish and standard Lunar Grey. An evolution of the CXN100, it runs on Cambridge Audio’s StreamMagic Gen 4 platform (iOS and Android) and adds HDMI eARC for direct TV integration.
The CXN100 SE is designed to handle both high resolution music streaming and TV audio within the same system, bringing broader connectivity into the CX ecosystem without changing the core signal path or overall sonic character.
CXN100 SE Feature Highlights
  • HDMI eARC (and ARC): Enables the CXN100 SE to receive digital audio directly from a TV, including sound from built-in apps and connected devices. Audio is then routed through the system just like any other source.
  • StreamMagic Platform: Uses Cambridge Audio’s 4th generation StreamMagic system for app control, settings, and access to streaming services on iOS and Android.
  • Streaming Support: Includes Spotify Connect, TIDAL Connect, Qobuz Connect, Amazon Music, Deezer, and internet radio. Also supports Roon Ready, AirPlay 2, Google Cast, Bluetooth, and MQA playback.
  • Wired Connectivity: Offers USB, coaxial, and TOSLINK digital inputs, along with balanced XLR and unbalanced RCA outputs, in addition to HDMI.
  • DAC: ESS ES9028Q2M SABRE32 Reference DAC for low distortion, wide dynamic range, and accurate timing.
  • Front Panel Display: 4.76-inch high-resolution color display showing album artwork, playback data, and optional VU-style meters for at-a-glance system feedback.
For a more detailed look at the CXN100 SE, check out our companion article.
Cambridge Audio-CNX100 SE Black Angle
CXN100 SE
The Bottom Line
The CXA81 MK II and CXC arrive in a new matte black finish with no changes under the hood, while the CXN100 SE adds HDMI eARC and expands system flexibility for both music and TV audio. That’s the only real hardware development here.
The more meaningful shift is behind the scenes, with new North American distribution that could improve availability and dealer support. As for the hardware, it remains solid and unchanged—still no built-in phono stage, and still aimed at listeners who prefer a clean, modular system over an all-in-one solution. The black finish just makes it easier to justify leaving it out in the open.
Price & Availability
Cambridge Audio CX Black series will be available from April 2026, but can be ordered now at the following prices:
QUAD ESL 2912X Electrostatic Speaker System at AXPONA 2026
Quad ESL 2912X electrostatic speakers at AXPONA 2026 from MoFi Distribution prove big panels can deliver clarity, scale, and real emotional connection without excess.
Amphion Stereo System AXPONA 2026 Amphion Stereo System AXPONA 2026
Amphion Argon7LX arrives at AXPONA 2026 with Finnish precision, clean power, and zero drama. No hype, just sound that quietly outperforms.
ATC EL50 Anniversary Active Speakers at AXPONA 2026 ATC EL50 Anniversary Active Speakers at AXPONA 2026
ATC EL50 debuts at AXPONA 2026 for $99,999. Does this active 3-way tower justify the price or fall short where it matters?
Geshelli TORC DAC at AXPONA 2026 Geshelli TORC DAC at AXPONA 2026
Geshelli's TORC DAC makes its case at AXPONA 2026 with a modular design, swappable DAC boards, and a real upgrade path that will not...
2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood 2026 Dynaudio Legend Bookshelf Speaker in Natural Rosewood
Dynaudio Legend bookshelf speakers hit AXPONA 2026 with Esotar 3 tweeter, real bass, and Danish build that proves the internet got this one wrong.
2026 Grado Phono Cartridges 2026 Grado Phono Cartridges
Grado updates its phono cartridge lineup with refined stylus, OCC copper coils, and improved designs across Lineage, Timbre, and Prestige series.
Cambridge Audio's MSX Series revives the Minx with compact modular speakers, BMR tech, and flexible sub options starting at $99.
Advance Paris debuts NOVA at AXPONA 2026 with modular integrated amplifiers, streaming and Bluetooth add-ons, but should streaming be optional at this price?
Shanling SM90 adds HDMI ARC, dual AKM DACs, and Android streaming under $1,000, but can it stand out in a crowded streamer market?
Can the $259 Fosi Audio S3 streamer DAC and preamp challenge WiiM and Bluesound with balanced outputs and HDMI eARC despite missing key features?
Does HDMI eARC support make the Cambridge Audio CXN100 SE a better $1,099 streamer for modern hi-fi systems?
At $4,999, the Michi Prestige X430 integrated stereo amplifier features 210 watts per channel, HDMI ARC and a new ESS DAC.
Can Emotiva’s BasX TA2+ revive the stereo receiver? With 135W power, HDMI ARC, balanced inputs, and phono support, it targets modern 2 channel systems.
Nagra Compact Player offers digital music streaming with DAC support up to PCM 384 kHz and DSD256. Is this the most attainable way into...
