Bang & Olufsen Unveils Design and Technology Refinements to the Beosound A5
The Bang & Olufsen Beosound A5 portable wireless speaker is now available in dark oak, nordic weave, and new spaced aluminium.
Bang & Olufsen A5 portable wireless speakers 2023
Bang & Olufsen’s Besound A5 portable wireless speaker was just released in April 2023 and the initial market reaction was quite positive. The Danish manufacturer, however, has just announced a number of design and technology changes for the wireless loudspeaker that has barely been in the market for seven months.
The new changes offer a more modern twist on an already attractive Scandinavian design.
The Besound A5 with Spaced Aluminium design honors the brand’s excellence in craftsmanship, with each speaker being handcrafted from over 3,500 aluminum discs in the brand’s Struer-based Factory 5
Bang & Olufsen A5 Spaced Aluminium
From Michael Henriksson Bang & Olufsen Vice President of Product Marketing: “We have worked with different circular patterns across our speaker grille designs for many years. It has become a signature, but this is a brand-new style…The look of the “floating discs” is created using a second layer of aluminum, carefully designed in a grid behind the surface to create the optical illusion and let the sound flow through”.
Modular Convenience
Beosound A5’s modular design allows users to easily swap the front cover to any of the three designs to suit their personal style and ensures that the speaker can be repaired and upgraded for an extended lifespan.
New Features
The launch of the new design and color also coincides with the introduction of two new features.
  • Automatic Stereo Pairing: Via software update, two Beosound A5 speakers can automatically pair once in range of one another. Using the B&O app (Android/iOS), Beosound A5 can also seamlessly integrate into a multi-product Bang & Olufsen home audio setup.
  • Fluid Sweet Spot: This enhancement provides a music listening experience as the artist intended. When stereo-paired, a single tap in the B&O app will let the Beosound A5 fix an ideal sound output based on the listener’s position.
Beosound A5
Beosound A5 provides big sound for a portable speaker. The A5 incorporates a four-way driver setup supported by four digital amplifiers providing a combined 280 watts of power.
The driver complemented includes 1 x 5.25” woofer, 2 x 2” midrange, and 1 x ¾ tweeter.
Bang & Olufsen Beosound A5 Speaker Drivers
Whilst taking aesthetic inspiration from Bang & Olufsen’s Beolit series, the technology in Beosound A5 draws from the class-leading Beolab 90 and 50 hi-fi speakers. Beamforming technology, an innovation first built into the Beolab series, was brought to Beosound A5 to control the sound with higher precision. This resulted in an immersive listening experience beyond what you would expect from a portable speaker.
As well as being a standalone speaker, B&O’s Mozart platform allows two Beosound A5s to connect seamlessly with each other in a stereo system or any other Mozart-enabled speaker in Bang & Olufsen’s portfolio.
The A5 can also integrate smoothly into a Bang & Olufsen smart home system, creating an immersive multiroom experience at the tap of a button. The Mozart Platform can be upgraded via periodic software updates or, when it is limit is reached, replaced by a new Mozart module.
The Beosound A5 is compatible with Beolink Multiroom, Airplay 2, Chromecast, Spotify Connect, Bluetooth 5.3, and more.
Bang & Olufsen Beosound A5 Portable Speaker in Dark Oak and Nordic Weave
Bang & Olufsen Beosound A5 Portable Speaker comes in Dark Oak or Nordic Weave
Specifications
Streaming Services
  • Apple AirPlay 2
  • Spotify Connect
  • Chromecast built-in
  • TIDAL Connect
  • B&O Radio
  • Deezer
  • QPlay 2.0
Amplification by Speaker (Class D)
  • Woofer: 1 x 70 watts
  • Full Range: 2 x 70 watts
  • Tweeter: 1 x 70 watts
Size & Performance
  • Battery Life: Up to 12 hours
  • Supported Audio Formats: MP3, WMA (WMA Lossless not supported), AAC, ALAC, FLAC, WAV, AIFF, OGG, HLS. Up to 24-bit/192kHz PCM
  • Maximum SPL: 101dB
  • Maximum SPL (Bass): 80 db
  • Frequency Response: 32Hz to 23kHZ
  • Dust and Weatherproof Rating: IP65 (Wood components and paper weave may be damaged by water)
  • Dimensions (WHD) with handle: 28.5  x 18.7  x 13 cm (11.22 x 7.36 x 5.12 inches)
  • Dimensions (WHD) without handle: 26 x 18.7 x 13 cm (10.2 x 7.36 x 5.12 inches)
  • Weight: Varies slightly with the finish, but starts about 3.7Kg (8 lbs 3 oz)
Bang & Olufsen A5 Spaced Aluminium with handle up
Availability and Pricing
Tip: The Besound A5 is also available with its original colors/design: Dark Oak or Nordic Weave
2 Comments
2 Comments
  1. Benjamin Smith
    October 29, 2023 at 9:04 pm
    You’d have to be on crack to think a Bluetooth speaker is worth $1399.00.
    • Ian White
      October 29, 2023 at 9:18 pm
      Benjamin,
      The KEF LSX II are definitely worth their asking price. I’ve yet to listen to the B&O so I can’t say if they are but there are a number of wireless/BT speakers that cost significantly more than the Beosound A5 and their sound quality is superb.
      IW
Emotiva Differential Reference Design Series Stack Front and Back Angle
Emotiva introduces an affordable line of fully balanced hi-fi separates for a discounted package price of $2,599.
Fosi Audio BT20A MAX Desktop Amplifier with Bluetooth Fosi Audio BT20A MAX Desktop Amplifier with Bluetooth
Fosi Audio’s $229.99 BT20A MAX packs a TI TPA3255 amp, real 2.1 power, and unusually robust Bluetooth codec support—does it deliver where it counts?
beyerdynamic HEADPHONE LAB on laptop screenshot beyerdynamic HEADPHONE LAB on laptop screenshot
beyerdynamic introduces Headphone Lab at NAMM 2026, a free plug-in that adds factory-calibrated, speaker-style monitoring to DT studio headphones.
Fosi Audio MD3 and DS3 Fosi Audio MD3 and DS3
Dongle DACs
Fosi Audio debuts the MD3 Magnetic and DS3 portable DAC/headphone amplifiers at CanJam Dubai 2026, focusing on compact design, XMOS processing, and IEM-friendly performance—not...
LG W6 Wallpaper TV at CES 2026 LG W6 Wallpaper TV at CES 2026
LG came on strong at CES 2026 with a new suite of OLED TVs featuring stunning design and impressive video performance.
Shanling CT90 CD Transport Silver Angle Large Shanling CT90 CD Transport Silver Angle Large
CD Players
Shanling’s $999 CT90 CD transport targets modern CD collectors with digital-only outputs and Bluetooth, but skips SACD, analog outs, and compact rack-friendly design.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
TCL’s A65K Design Series soundbar features 3.1.2 channels, 460-watts of power and Bang & Olufsen tuning, but pricing and final specs won’t arrive until...
Loudspeakers
Bang & Olufsen bets big on Union Square’s comeback, opening its largest store in a San Francisco still digging out from years of crime...
Looking for the best compact wireless speaker? Our favorite models from Brane, DALI, Devialet and Bang & Olufsen can go wherever you go.
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
Bang & Olufsen turns 100 with the Beolab 90 Titan Edition—a $200,000+ statement in aluminum and ego that proves audiophile excess is alive and...
Bang & Olufsen claims Canvas The HiFi Frame (left) infringes on their Beovision Contour TV (right) design, but do they have case?
Bang & Olufsen marks 100 years with The Centennial Collection, reimagining the Beoplay H100, Beosound A5 and A9--stylish, nostalgic, and light on innovation.
Four Season’s Yachts elevates comfort and style on their luxury cruise line with LG's Transparent TV and Bang & Olufsen sound.
