Audiovector Unveils R 10 Arreté: Bold Danish Engineering Redefining Flagship Loudspeakers at HIGH END Munich 2025
$160,000 flagship loudspeakers designed to rival the best from DALI, Estelon, and Focal. Discover how Danish engineering and over a decade of innovation come together in their most ambitious design yet.
Audiovector R 10 Arreté Loudspeakers
Audiovector is unveiling its flagship loudspeaker, the R 10 Arreté—and make no mistake, this isn’t your average exercise in Scandinavian minimalism. Premiering at HIGH END Munich 2025, the R 10 is where 45 years of Danish craftsmanship meets a bold refusal to stay quiet. Available soon through select partner distributors, this is a loudspeaker built not just to play music, but to command your attention.
Denmark is known for its quiet obsession with craftsmanship: clean lines, refined woods, and design that whispers rather than shouts. But the R 10 Arreté isn’t whispering. It’s sculpted from premium hardwoods like African Mahogany Crotch Piano, Canadian Birdseye Maple Piano, and Italian Walnut Burl—materials usually reserved for fine furniture, not sonic sledgehammers.
It’s visually arresting and acoustically uncompromising, proving that even in Denmark, sometimes form and function get a little loud. A plate of herring and rye bread may still have its place, but this speaker pairs better with a neat pour of something rare and a volume knob that dares you to turn it further.
“Our ambition was to create something timeless and uncompromising—both in appearance and performance,” says Audiovector CEO Mads Klifoth. “The R 10 has been developed entirely from the ground up, with every component—from the cabinet to the drive units—purpose-built to deliver the most natural, dynamic, and open sound we’ve ever achieved.”
This speaker doesn’t just top our previous benchmark, the R 8 Arreté—it’s the culmination of ten years of collaboration between my father, Ole, and myself,” says Mads Klifoth, CEO of Audiovector. “We’ve spent those years relentlessly pushing the boundaries of what’s possible in loudspeaker design. The R 10 is the result: a statement of passion, precision, and a bit of family-driven stubbornness,” he adds with a grin.
audiovector-r10-loudspeaker-pair
Dual AMT Tweeter
The R 10 Arreté features a Dual AMT Tweeter, integrated with Audiovector’s Soundstage Enhancement Concept (SEC). This ensures a treble response that’s not just clear but spacious, delivering a sound that goes beyond mere hearing and into the realm of feeling.
The main AMT tweeter covers 3,000 Hz to 53,000 Hz, while a dedicated hyper tweeter extends this to 20,000 Hz–53,000 Hz, well beyond what any human ear can detect. But, of course, that’s the point: it’s all about pulling out the finest details and creating a soundstage with superb imaging and micro-dynamics.
8 Bass Drivers
At the rear, the R 10 Arreté boasts a unique array of eight bass drivers, each working together to deliver the equivalent surface area and displacement of a 15-inch woofer. This design ensures deep bass extension with controlled articulation, eliminating cabinet-induced pressure buildup. The result is bass that’s not just profound but fast, powerful, and tightly controlled. Audiovector’s goal here? To let you experience bass without the usual muddiness.
audiovector-r10-side
Accelerated Force Concept
Audiovector’s Accelerated Force Concept (AFC) bass/midrange structure isn’t your average design. It allows the drive units to accelerate and decelerate with precision, delivering a response that’s as fast as it is controlled. The result? Low distortion and a physical presence in the sound that you can hear and feel—without the usual distortion or delays.
Controlled Resonance
With a uniquely flexible damping feature, the R 10 Arreté aligns cabinet resonance and energy release to work in perfect harmony with the music. The result is a calm, controlled performance that feels profoundly musical without unnecessary embellishment.
audiovector-r10-midrange
Line Array Bass System
The R 10 Arreté’s rear-facing bass line source uses eight long-throw drivers, each with a linear travel of ±12 mm, giving it the surface area of a 15-inch driver. But by dividing the bass across multiple drivers, Audiovector achieves greater speed and precision. These drivers reach up to 2,000 Hz, providing a tapered frequency response that adds to the speaker’s overall fast, precise, and undistorted sound.
The front baffle features two additional bass drivers, adding extra clarity to the lower midrange—where a lot of the musical dynamics live. This combination of rear-facing and front-facing drivers creates a soundstage that’s both expansive and immersive, with bass that’s deep and impactful without taking over the entire room.
Specifications
  • Frequency Response: 21 Hz – 53 kHz
  • Impedance: 8 Ohms (nominal), 5 Ohms (minimum)
  • Sensitivity: 90 dB / 1W
  • Crossover Frequencies: 180 Hz, 450 Hz, 3,000 Hz, 20,000 Hz
  • Bass Drivers: 8 × 5″ long-throw, low-distortion
  • Lower Midrange: 2 × 6.5″ AFC carbon sandwich
  • Midrange: 1 × 6.5″ AFC carbon sandwich
  • Main Tweeter: 3,800 mm² AMT N51
  • Extended Tweeter: 3,800 mm² AMT N51
  • Terminals: High Current Nextgen Bi-Wire (compatible with 4mm plugs or spades)
  • Dimensions: H: 156 cm × W: 36.5 cm × D: 62.7 cm (without spikes)
  • Weight: ~95 kg per speaker
  • Finishes:
    • Canadian Birdseye Maple
    • African Mahogany Crotch
    • Italian Walnut Burl
    • All piano lacquered; custom finishes available on request
audiovector-r10-finishes
The Bottom Line
The R 10 Arreté isn’t just a flagship—it’s Audiovector’s clearest statement yet that it intends to compete at the top of the high-end loudspeaker market. With its debut at HIGH END Munich 2025, the Danish brand is aiming directly at rivals like DALI, Estelon, and Focal, putting a decade of research and design into a speaker built to stand shoulder to shoulder with the best.
Handcrafted with precision from premium, high-density wood, the R 10 Arreté is finished in African Mahogany Crotch Piano, Canadian Birdseye Maple Piano, and Italian Walnut Burl Piano. It’s not just a speaker; it’s the kind of craftsmanship that leaves no room for excuses.
If you’re attending the show, swing by Atrium 4.2 F203 (A4.2 F203) between 15:00–17:00 on Thursday, May 15th, and see firsthand how a decade of Danish audio innovation can sound.
MSRP: $160,000/pair
For more information: Audiovector R 10 Arreté
4 Comments
4 Comments
  1. Anton Vanderlay
    May 3, 2025 at 7:13 pm
    Love the look but $150K? That’s a lot of money for a pair of loudspeakers. Must be nice to have that level of money to drop on audio equipment. Much prettier looking than the Focal.
    The DALI are not lookers. Finish doesn’t scream $100K+.
    • Ian White
      May 3, 2025 at 7:52 pm
      So having just spent time with a more affordable Audiovector loudspeaker that I will be writing up this month, these have the potential to be rather special speakers.
      Not that I would ever spend $150K on any pair of loudspeakers — even if money was of no matter.
      $6-7,000K is my absolute ceiling but I’m far more interested in the $500 to $2,000 segment.
      Lord Cheapskate
  2. John Norris
    May 4, 2025 at 1:08 pm
    Does a $160,000 speaker even matter? Maybe to smarmy divorce lawyers or neurosurgeons, but not to 99.999% of us.
    • Ian White
      May 4, 2025 at 1:33 pm
      John,
      So one of the things that guides me, is giving readers a full picture of the industry. The majority of our reviews and stories (as you’ll see today and almost every day) are on the entry-level and mid-tier. But that doesn’t mean we ignore products that perhaps 100 people might consider — even if I agree with you 1000% that spending $160K on a speaker makes zero sense.
      IW
2026 Technics Fritz Hansen Limited Edition SL-40CBT Turntable
Technics gives the SL-40CBT Bluetooth turntable a limited Fritz Hansen makeover, proving Danish design still knows how to shame a living room.
Wharfedale Elysian R Series Loudspeakers in Grey Wharfedale Elysian R Series Loudspeakers in Grey
Wharfedale Elysian R Series debuts with upgraded AMT tweeters, revised drivers, SLPP bass loading, and flagship performance from $5,995.
JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed JL Audio Pavilion Thin-Line Subwoofer Round Vs Square Installed
In-Wall Speakers
Hide a subwoofer in your walls or ceiling with JL Audio Pavilion Thin-line 8-inch Subwoofers at $1,000 each.
Leica Cine Compact 1 Lifestyle Projector Leica Cine Compact 1 Lifestyle Projector
Leica's $2,000 Cine Compact 1 adds RGB laser, 4K pixel shifting, Dolby Vision, smart streaming, and a Summicron lens. Worth the red dot premium?
FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle FiiO Jade Audio LEVEL 1 Amplifier Black Front Lifestyle
FiiO debuts the Jade Audio LEVEL 1 desktop amp, JT9 planar headphones, and CLASS A headphone amp at High End Vienna 2026.
Yamaha NX-70A Wireless Speakers on stands lifestyle in black Yamaha NX-70A Wireless Speakers on stands lifestyle in black
Yamaha's NX-70A wireless speakers bring HDMI eARC, YPAO, Roon Ready support, and active stereo performance for around $3,500.
Father's Day 2026 Gift Guide
12 gift ideas for the music and movie loving Dad that are guaranteed to delight this Father's Day.
We heard the Bowers & Wilkins 801 D5 in a proper demo room at High End Vienna 2026. So, is it a worthy successor...
Focal has upped the ante with the flagship Bathys MG wireless headphones and that includes a $600 increase in price over the base model.
Børresen debuts its new A-Series loudspeakers at High End Vienna 2026, bringing Danish-built tech below its costlier C and M models.
The new generation Summit Everest and K2 join the previously released Makalu, Pumori, and Ama in an ultimate high-end JBL speaker line-up.
JBL's Summit Series audiophile loudspeakers, the Makalu, Pumori, and Ama, honor 80 years of acoustic precision and emotional power.
The company’s latest Diamond D5 version of the 800 series speakers feature a host of new technologies and design refinements to cement the speaker’s...
McIntosh MA2375 debuts as a $15,000 all-tube integrated amplifier with 75-watts per channel, MM/MC phono, headphone amp, and no digital extras.
