Front and center speakers
manent
Hi everyone,
I'm looking to upgrade my front and center speakers. I'm currently running JBL and they're too damn bright. They hurt my ears! I want a smooth (warm) sound. My surrounds are mirage om-r2 and my rear surrounds are mirage Omni fx. I have tower speakers right now but I dont think I need towers anymore since the purchase of My HSU STF-3 Subwoofer. This system is 95% Home theater.
I dont mind mismatching front and back speakers.
receiver is pioneer 1014
room size 12 X 24 (basement)
budget is 800 to 1000 US for all three speakers
Any suggestions?
Thanks for your insight
Eric
Username: Project6
Post Number: 4704
Have you considered another set of Mirage Speakers for front and center?
manent
Yes I have, I just wanted to consider other alternatives like paradigm or axiom or others
Username: Project6
Post Number: 4755
Axioms are excellent, but others have found them a tad bright so you may not like them. Paradigms would probably agree more with your tastes so give them a try. Look at the Atoms.
Then there is Ascend Acoustics and should fall within your budget. Another excellent set of speakers well detailed but not bright at all.
manent
Thanks for the help
