Is there any way to convert .vod format?
Username: Cleric
Does anyone know how to convert this to avi or mpeg? I have a Philips DVDR and I'd like to be able to edit these files on PC. Any help would be appreciated.
Username: Samijubal
Post Number: 182
Have you tried TMPGne or Womble?
Username: Cleric
I looked at both of those but I cannot find any reference for a .vod file extension. Plenty of VCD stuff, but not VOD.
Username: Samijubal
Post Number: 184
Are you sure that's not VOB? Never heard of VOD.
Username: Cleric
Post Number: 9
David, you are correct. And I've since found that Win DVD creator 2 will convert this format. Thanks for your help.
