How to find the input channel for RCA TV
Username: Romocop
I'm trying to connect my XBOX 360 to my RCA tv. The TV was purchased in 2002. The model # is J25435. It has the red, yellow, & white connectors but the game doesn't show. I have tried every channel and none works. XBOX said I need to find out how to change the input or get to the input mode on the TV. I don't have the original remote and the menu button on the TV does not bring up those options. Can anyone help? Please!
Username: Samijubal
Post Number: 4337
The line input is 92 or 93 if I remember right.
Username: Romocop
There are many channels including 92 and 93 that will not appear when I punch them in on the remote. So how do I get to them? I bought a new remote from (Radio Shack #15-302). It was programmed properly the channels will not come in. Now what? Thanks for the help.
Username: Samijubal
Post Number: 4340
I may be wrong on the channel. It should be somewhere between 91 and 102.
Username: Romocop
No Luck. No channels above 98 and 91 is not accessible.
Username: Samijubal
Post Number: 4341
I don't know. It should be channel 92 I believe. All I can say is try changing something in the menus. The original remote may have had an aux/input key on it.
Need to Register?
Forgot Password?
Enable HTML code in message
