Viewsat Max HD problem
Username: Zagros
Post Number: 384
May Max HD can not find more than a handful of HD channels.
I have a Bell 18 inch dish with 2 LNBs and have tried different settings as well as cannel scan, blind scan, also reloading the file, no luck.
Can anyone help please?
Username: Plymouth
Post Number: 15997
Zagros
How is the signal and quality?
Username: Zagros
Post Number: 385
The signal is good. I don't think that is the problem.
Username: Plymouth
Post Number: 16004
You can have Vertical signal good but Horizontal too low!
Those channels are available or not?
Are you talking about IKS?
Username: Zagros
Post Number: 386
I am taking about IKS.
Here are some pictiures of the LNBs I am using. Do you know what type they are?
And no plymouth, that is not the case.
This is a picture of the LNBs I use, can you tell me what the settings for them should be?
Username: Zagros
Post Number: 387
No Plymouth that is not the case. and yes I am talking about IKS.
Here is pic of my LNBs, Can you tell me what setting I should have?Upload
Username: Zagros
Post Number: 388
Username: Plymouth
Post Number: 16005
OK for the LNB's but I don't know which satellites you are looking for and if those channels are available on the listing of your IKS provider!
With these infos, it will be easier to answer!
Is this a new problem or you have never taken these HD channels?
Username: Zagros
Post Number: 389
It dosent' have anything to do with provider or which sats I am serching. It can not find the HD Channels.
110, 119 are the sats I am looking at. Even with the factory bin the problem is the sam.
Username: Plymouth
Post Number: 16006
Do you have the SK200 module necessary to get the HD channels from Dn?
Username: Zagros
Post Number: 390
Yes I do.
As I said I can get just a few of the hd s mostly ppv.
I think the problem is LNB settings.
Username: Plymouth
Post Number: 16007
Post your setting for each satellite(110-119)
LNB type, LNB Freq, Tp Freq etc
Username: Zagros
Post Number: 391
Well, I think that is the problem.
I tried Different settings, but in most cases there is signal for the SD but no signal for HD transponders exept for one or two of them.
Username: Plymouth
Post Number: 16008
I wait!
Username: Chaff
Post Number: 589
18' dish is for one sat, you need 20" dish to get 2 sats .
Username: Plymouth
Post Number: 16009
Most of HD channels are on 110W and work fine with a 18"!
Username: Statues
I cant get the French channels
Username: Zagros
Post Number: 392
Chaf, it was originally used by Bell for 82 and 91. If Bell is using that dish for thier customers, it should be good enough. I am not home right now to mesure it again but it might be 20 inch.
Username: Chaff
Post Number: 590
sure they do .. but if you try to make that 18' into a dish 500 you will have problems.
playmouth, surprised you haven't told the op to reboot yet..you fookin retard
Username: Zagros
Post Number: 393
What do you mean by making it into dish 500?
Username: Statues
Post Number: 7
Reboot lol Chaf What do you expect from a puppet on a string lol
Username: Zagros
Post Number: 394
Guys please do not turn this into a personal battlefield.
Thank you
Username: Plymouth
Post Number: 16010
Chaff go play with your stupid newbie!
Zagros
The Bell dish work fine on 110 and 119, the only problem is with the lower transponder frequencies on Anik F3 118.8W which need a special LNB!
I took 129W with a 18" in Quebec without any problem!
Username: Chaff
Post Number: 591
Theres only a handful of transponders that have hd content...
one @ 119w TP 12311
@110
12311
12399
12457
12846
all have symbol rate of 21500
AND
FEC 2/3
Username: Plymouth
Post Number: 16011
Be sure that the skew is right for those satellites
Use this utility to set your dish:
http://www.dishpointer.com/
Username: Plymouth
Post Number: 16012
Here are the HD channels(in Green):
http://www.lyngsat.com/packages/dish110.html
http://www.lyngsat.com/packages/dish119.html
