I don't know much about satellites or how to set them up. Recently, I tried to upload a new file to my nfusion solaris, and it went nuts. So I changed it back to Factory Default. Everything's been wiped clean, including the User Settings, Antenna Settings, and etc. I live in Ottawa, Canada, I have two dishes, my LNB Types are Standard as I understand it (I have two LNBs on one of the dishes though, don't know if it makes a difference). So the dishes are pointed right and everything, now I'm wondering if anyone could tell me the Antenna Settings, User Setting, and etc I need to enter to get my channels back. Also, I read that nfusion is down anyways, so I might get my friend's Viewsat Ultra, so it would also help a lot if you could tell me the settings I should use for that just in case. I tried to enter some things i read in threads and stuff, nothing works. Even though I get some good S&Q still when I scan for channels none work. Any help will be very much appreciated!
"Quoto" WahidN........ including the User Settings, Antenna Settings I have two dishes, my LNB Types are Standard as I understand it (I have two LNBs on one of the dishes though, don't know if it makes a difference). So the dishes are pointed right and everything, now I'm wondering if anyone could tell me the Antenna Settings, User Setting,
Could you tell us what satellites are you two Dishes pointed to?
97w and 61.5, and those are the two I get pretty good signals on. It's just that channels that scan don't work at all, or I might be doing something wrong.
when i put it on universal before i also got a LNB Freq LO which i don't know what to enter. Also, it is still in factory default, do i need to upload a new bin?
I have no idea what linear LNB is. I've got two dishes one with one LNB and the other has two LNBs attached. And i guess somewhere there is a switch connecting all together.
WahidN Your Receiver Setting for Galaxy 19 at 97.0°W seem to be OK. Try this, point your largest dish to Galaxy 19, the dish from your location must be at lest 33" a 36" would be better with a Linear LNB From your location Ottawa, Canada use these settings
Yes, they've worked until I tried to upload a new bin on nfusion. Right now I am not at home, but I will follow every step and post the results. So I guess I just should leave it at factory default then? Thanks a lot for your help guys!
So I did everything you guys told me. I got really Strong signals Lock TP 11936 h 20000, but after the scan just as before, the channels don't work. Black screen, it does say "Service not available i-ON / n-ON / p-OFF / Emul-OFF / SUNS Connected" No idea what that means. And the scan only gave me about 60 channels.
