cnxemu v0.1a (alpha release) cnxemu v0.1a (alpha release) ---------------------------- This Linux app acts like an "IX-200" dongle for Conaxsat boxes. It will allow you to use your Conaxsat with normal SSSP clients by converting the "IX-200" dongle format into a more usable "Captiveworks" SSSP format.
This is compiled for i386 basic CPU type, and will run on any Intel-like Linux system. With x86_64 you will probably need the 32-bit compatibility packages installed, however you do that on your distro.
Usage: ./cnxemu <serial>
If no serial device is given, the default is /dev/ttyS0 You must provide the entire path to the device (include /dev/ always) You need a "null modem" cable between the Conaxsat and your Linux box.
Upon launch, it will report which PTY device (fake serial port) it has created for use by your SSSP client software. Configure your SSSP client to use that port instead of a normal serial device, and make sure it also supports normal "Captiveworks" type SSSP format, as that is what this app outputs. Of course you also need to configure your SSSP client to give it some card sharing server(s) or not much will happen.
This has only been tested with rq-sssp-client v1.04, but there should be no reason any other SSSP client shouldn't work as well, as long as you can get them to use a specific device. Some may require symlinks or fiddling to trick them into opening the PTY device rather than a more standard one. (hint: "sudo ln -s /dev/pts/8 /dev/ttyS5" and then set your SSSP client to use /dev/ttyS5 or "COM6" or such, depending on what it expects)
Note the menus on the Conaxsat will show normal information as expected, and any networking changes are accepted but silently ignored. They don't matter anyway and you should be configuring your Linux box as normal, so it can get to the servers you use in your SSSP client. This app does not do any actual network socket connection, it is only a bridge between the Conaxsat format and the Captiveworks SSSP format (your SSSP client is what connects to the server). This also has nothing to do with the server(s) the real dongle would connect to, it just allows you to use the dongle-enabled STB firmware to do the same thing most other generic SSSP-enabled receivers can do.
You must run this app and the SSSP client app on the same Linux box, in case you thought you didn't. The PTY device is only available locally. So just use "screen" or pop another terminal/console window and be sure to run cnxemu first (since it dynamically creates the PTY device) and the SSSP client next. Also if you stop cnxemu with CTRL-C, it will automatically locate and kill the SSSP client (or whatever is on the other end of the PTY), so no more worries about it camping out on the device for the next launch of cnxemu. You do still need to manually fire up the SSSP client when you start cnxemu again - and cnxemu will complain rather loudly if nothing is picking up the other end of the PTY, to remind you.
Proper Setup Procedure (tested on the original Nano): 1) IF YOU HAVE A NANO: Obtain these three bins and put them on USB stick: NAN_7.10_Factory.NPB ("factory" bin) NAN_4.22.NPB (the "422" bin) IF YOU HAVE A DIFFERENT MODEL: Same as above just the ones for that instead. 2) Connect the USB stick to the front USB port, fire up the STB 3) Go to menu "Utility" -> "USB" 4) Navigate to the factory bin, select it, install using "Bootloader" option 5) Wait for it to finish and reboot. Sometimes it will sit there with 0 on the front panel, press the remote power button if so (it's in soft-off) 6) Go to menu "Utility" -> "Factory Default", enter PIN, say yes 7) Repeat step 3-6 but with the "422" bin instead 8) Connect serial. Fire up cnxemu. Double check /dev/pts/ path and set it in your SSSP client. Fire up the SSSP client. (use "screen" or two terms) 9) Go to menu "Utility" -> "System Information" and watch the bottom line for it to change from "unknown" to "cnxemu v0.1a" (it will take a second) This verifies your serial connection and that cnxemu is ready. 10) Set up your satellites and do an autoscan, etc 11) Go to a channel you know your IKS provider handles, watch TV.
i never tried this so use it on ur own risk i got nano2 which is very easy to convert takes max 3 mins.. i am not so sure about this.. u can get more help at www.ftabeta.com
