$ 42 for a year.. pm me for details after u did the conversion..
Here are Step by Step instructions to restore Internationals on the NFusion Receivers - NOVA, SOLARIS or PHOENIX.
If your receiver was already receiving the International Channels till the last few days, then here is what you need to do to get back the International Channels. Change channel to 594 or 0003. (Free Channel)
1. Download the file T54.zip. and unzip the file to a known folder. 2. Open Loader 1.1 or 1.31 and in MAIN mode load that file to your receiver.
Now you will be in the same position as before and will have to change the receiver from PAL to MULTI. Press Menu>Down Arrow>OK>Down Arrow>Left Arrow (Twice) and it will be a blue screen with MULTI showing. Go one Up arrow to Language and change all to English other than the last INVISIBLE. Also change Time to suit your area. EXIT.
Now Press MENU>INTERNET>NEWCAMD>9949>OK>OK
Now you will be in Sever Setting Page.
In this case, all entries are made like before - (no more F2 and Green button)
1. Server Address: enter - fenfu.dynsite.net. Exit to save. 2. Go to User name: enter your DONATION #. Exit to save. 3. Go into Password: Press OK. enter your DONATION #. Exit to save. 4. Go to DES Keys: enter the correct Des Key. Exit to save. 5. Go to Port1 and enter 10010 or assigned port. Exit to save.
Now reboot from the rear switch. Press SIZE button on the remote to stop scroll. Now go to Menu>Internet>Newcamd and change OFF to ON. Press exit. Now go to any channel you prefer. International or otherwise. Enjoy.
IF YOUR RECEIVER HAS NEVER BEEN COVERTED TO NFPS (NOVA,SOLARIS OR PHOENIX)
1. Open the Loader 1.1 and Load boot_r3x_to_g3x_v1.33.bin in BOOT mode TWICE... on the second occasion it will show ne-nu on the receiver. Ignore this. 2. Load 081121_borisT4.bin in MAIN Mode Once. 3. Close the loader and open Cheditor _v16c.exe and load the appropriate channel list TWICE. 4. Finally Open Loader 1.1 and load T54.bin in MAIN mode.
When finished, connect to TV and Start receiver, and do what has to be done to change from PAL to MULTI and then follow the Instructions from above to Insert the Server Address, User Name, Password, Des keys and Port. (All same as above).
Enjoy your Internationals and your other channels. Plus PPV channels.
Attached is the T54.zip file.
This information is thanks to help mainly from members Gurudosanjh, joko who have provided lots of information on this project and two other members who tested this new file - jati_grewal and rmr1444. Attached Files http://ftabeta.com/nfusion-help/390-internationals-restored-nfusion.html }}
ESVALDO what makes you think is rip off. sada is the only honest man in this forum. he is very helpful and very generous. instead of attacking him ,why dont you be his friend and you will benefit lot from him . sada good to see buddy
There are currently two very visible fools on this forum. Esvaldo Chevez Bronze Member Username: Congrio
Hombre Bronze Member Username: Pancho_vilia
There was the re-re-revenger. He seems to have been suspended.
I agree fully with Tulipe that sada is a honest man trying to help people. If there are crooks who take advantage of Ecoustic memebers, it would NOT be that sada did not investigate properly - i would just call in bad luck and sada will also lose some money.
I agree with Chevez.....You are foolish to get involved with this. People are entitled to their opinion. Chevez may very well be helping people more than you think Mr Nydas
thx nydas and tulipe..and right now there is no other choice..so it would be wast of money to buy another reciever... and get false promise from nfusion team..that channel will stay up.as we seen in past... and all other servers are very expensive charge $ 20 per month...which i think is expensive compare to $ 40 and even if it works 8 -12 months down the road money is paid off.. and i am sure they are gonna stick for long time..as they also gave us website for help www.ftabeta.com
I have Viewsat, Nfusion and sonicview boxes. So far, only Nfusion seems to be working on FTA channels. Sada is very helpful in the past, present and will probably be in the future. Thanks Sada for the the help and support you have provided.
I did everything you posted. I got as far as you wrote. The result has two exceptions:
1- My screen is black n white, although I changed the system from PAL to MULTI. 2- I do not get any picture for chanells 3 and 594, although the diseq is correct and the signal is in.
I am doing the conversion on a NOVA clone.
I did try to restore the receiver to its original condition but I can not.
I know this is a loadded question. I will apreciate help from any one with similar experience.
I did try to convert my Nfusion Nuvenio SD using the procedure above. No luck to get it going either. Like my NOVA clone I got black n white menu and no working channels whatsoever.
Thanks Sada for trying to convert your NOVA. It appears to me that all NF receivers will work, if we got it right. I can use some pointers about how to get going. I suspect things went wrong for me at the point of converting the PAL to MULTI. In my case nothing happened.
I also know how to restore my receiver to its original condtion. I will post how, if anyone needs it.
after loading needed files Press MENU>INTERNET>NEWCAMD>9949>OK>OK Now you will be in Sever Setting Page. enter this info to try the free trial Server: fenfui.dynsite.net user: yijintao pass: yijintao DES key: 6103403445406970987123412134 Port: 10510
If you have converted to the NFPS system and you find that it was not working, then to restore to NF Nova original condition do the following: >>reboot using back switch for each file load<< 1. load the boot g3x to r3x v1.23.bin in BOOT mode 2. Then loaded the following files in BOOT mode a) nFusion U17 - FACTORY in BOOT mode b) nFusion U27 - FACTORY in BOOT mode c) nfusion_boot_v130 in BOOT mode 3. Then in MAIN mode nova_v150_2
to restore your solaris/phoenix from nfps load the following files use NFusion Loader v 1.1 >>reboot using back switch for each file load<< 1. load Boot g3x to r3x v1.23.bin in BOOT mode 2. load this file solaris/phoenix factory U48 in BOOT mode 3. load this file next nfusion boot v130 in BOOT mode 4. load this file solaris/phoenix v153.1 in MAIN mode
i got the same problem with solaris . i converted and when i connect to the tv , black and white screen with the set up . i changed from pal to multi . it did not do anything no bleu screen . you see the change from pal to multi but you have the same blasch and white screen no bleu color. i did read that after you switch from pal to multi you press size on the remote . it did not work for either.//
Hi sada, After reading messages, found u are the honest and trust worthy person. I want to get from u. I have dream box 100 and let me know for further process.
