Trying to get sat 97w
Username: Fta_g2
hey.
1)i am trying to get galaxy 19 on my nfusion ,but i couldnt find it, instead i found galaxy 25(97w)...is they are the same .or what?
2)if they are the same i was trying to get it on my nfusion but i couldnt get it, i have 118,119,110.but i cant get it...what do i need to do?
Username: Gastrognome
Post Number: 116
They could be the same... galaxy 25 was at 97w but was replaced by galaxy 19....if galaxy 19 isn't in your menu , use g .25
97w ( and the other fta sats) require a linear lnb and atleast a 30" dish, the other sats you have use a circular lnb.
Username: Nydas
Post Number: 19807
Galaxy 19 is a C and KU band satellite. Does not matter what your receiver says about 97W - Old information would say Galaxy 25.
Galaxy 19 requires LNB capable of of both but if you are only intersted in th eKU band frequencies a simgle would do.
See lyngsat for the available TPs
Galaxy 25 is at 93.1W is all KU but has very little programming
Username: Fta_g2
well my dish is 30" dish and have 2 lnb which it(DP Dual Band LNBF for orbital locations for 118.7°, 119°, and DP Single LNBF for 110°) like the pic
belowUpload
if those lnb cant get 97 ,can u show me a pic or a link showing which lnb i need to use,
also i was think if the 110 is the single lnb, can i remove it and add the new lnb for 97 , or move this(110) lnb to 97
thanks for ur help bro
Username: Nydas
Post Number: 19808
Username: Plymouth
Post Number: 14934
Welcome to eCoustics fta g2!
You can't get Globecast 97w with this dish!
You need a 33'' or 36'' dish then a linear LNB, the Dn dish is circular, do not lose your time with it!
Username: Pirate_pete_208
Post Number: 261
nydasPlatinum Member
Username: Nydas
Post Number: 19808
Posted on Saturday, October 02, 2010 - 05:50 pm:
over 4 years and 20,000 posts
Username: Toothpic
shes not that bright
Post Number: 262
Fta_g2
Dish size depends on your location
don't replace your Dish before you
try this first, just replace your 110 LNB
with a Linear Lnb and point it to Galaxy 19 at 97.0°W
Post Number: 263
Toothpic New member
Welcome to our laughing place
I can see you know her.
stick around the Fun Bunch could use
few good men
Btw....nice nick..
.Toothpic
Username: Plymouth
Post Number: 14974
Cpt Hook
30'' is too small to get all Tp's from Globecast, for sure he will get some Tp's but with a rainy day?????
Post Number: 267
Maybe you are wright, but it all depends where is his location.
to start out with it is much easier and less expensive
to try with a Linear LNB first. If he is located with-in 49.5 dBW
or less his Dish will work
Username: Plymouth
Post Number: 14980
Hook
I'm under the strongest zone with a 33'' then my signal is on the border to be loss!
He can found a 33'' with linear for only 60$
