Nfusion Phoenix Color Problem
Username: Saskboy02
Post Number: 7
I got my receiver back up and running but my color is all messed up. How can I get it straightened out? I tried a Factory reset but nothing changed.
Thanks!
Username: Plymouth
Post Number: 14319
Barry
Are you hooked on componants output?
If yes! Check if your cable are in the good color output!
Username: Saskboy02
Post Number: 8
That did the trick. Wife was dusting and pulled to hard on the box and loosened some of the plugs!!
Thanks!!
Username: Plymouth
Post Number: 14327
Barry
You are Welcome!
