CNX
Username: Lauchie411
Inverness, Nova scotia Canada
Post Number: 103
i have the nano 2, do they show the ufc's????
Username: Ram710
Post Number: 21
is conaxsat nano 2 up some tell me please
Username: Nydas
Post Number: 18393
Yes It is up. What is your problem?
Username: Ram710
Post Number: 22
my power went out and come on back and it stop working i turn it off and put it on it still not working which is the boot file for it npn 8.06 or npn1.28 npn
Username: Nydas
Post Number: 18395
At cnxdongle site, you will find the latest factory file NPN 8.06. Download it, unzip and install it.
Next you download the lastest file, NPN 1.28.zip, unzip it, and install it. Disconnect the Ethernet cable, wait a minute and connect it again.
Username: Nydas
Post Number: 18397
You may have to rescan, if the channels do not come in after the above procedure.
