Dishnet sub reciver help
Username: Sam_patel
Post Number: 135
hii i have a sub dishnet work reciver and all indian channels are working but im missing one channel 718 star one indian channel and it's not in list also this channel are not in guide i chack on all channel but there is no 718 star one channel is there any help thanks
Username: Plymouth
Post Number: 12026
Sam
You can do a factory default, your receiver will scan your channel automaticaly.
If after a scan it not work, your dish could be realigned.
Username: Sam_patel
Post Number: 136
yes i did factory default but sitll missing .... thanks for you help Plymouth.
Username: Plymouth
Post Number: 12027
Sam
Are you able to get Star Plus USA on the same transponder?
Check in Installation the signal bar on Tp17 is you have a strong signal.
Username: Sam_patel
Post Number: 137
yes
Username: Nydas
Post Number: 17104
If you are getting 716 then you should get 718, and vice versa.
Username: Sam_patel
Post Number: 138
now what can i do , i dont get 718 so is there any help we can do on reciver thanks !
Username: Plymouth
Post Number: 12029
Sam
Call Dish they will help you!
Username: Nydas
Post Number: 17105
You have a sub. If possible, you should call Dish Network and see what they could do to help.
Username: Sam_patel
Post Number: 139
im from canada so i cant call !
Username: Nydas
Post Number: 17106
Do you have a 311 or 322?
Are you scanning 61.5 or 118.7?
If 118.7, what LNB?
Username: Plymouth
Post Number: 12030
Sam
Are you serious!
You have a little problem!
They do it when the phone is not hooked!
Username: Sam_patel
Post Number: 140
yes im serious and i get this reciver from my uncle's home he had two reciver so he give me one so and i was in usa and i got home yday and im liveing in sudbury ontario so .
and yes i did try both it's same problem thanks
Username: Lomna
Sac, Calif U.S.A
Post Number: 873
Sam , you still can call. Why not ? Need not to give all the details. All they need the name on the account and acct number you have that right ??? Make sure your recr should be aimed at the 61 or 118 ?
You should be good.
