Sonysat help
Username: Jowhar
Post Number: 311
Any one Knows how to put the bin on Sonysat 5500 do I have to Extract the file or not traing to help my friend.
Username: Chumley
Post Number: 771
Extract and put on usb stick. and in menu ,you select utility and usb (upgrade).. after that do your antenna setup and scan, then load file for x-2 dongle with wiznet.
Username: Jowhar
Post Number: 312
thank Chumley is there a loader.
Username: Chumley
Post Number: 773
I believe you load the cyclops bins with a usb stick and the x-2 file with wiznet.
Username: Akhan64
Toronto, On Ca
Post Number: 22
How many desi channel are shown on SONYSAT?
Username: Jowhar
Post Number: 313
When I extract the file can I draged to usb stick.Thanks
Username: Nydas
Post Number: 17068
All STBs with USB ports for loading files, allow you to load a file via USB port.
If for any reason you are unsuccesful, you can always revert to the old method of uploading a file via serial port using a straight or a null serial DB9 cable.
All downloaded files come usually as zipped files - some come with rar comression. In either case, you have to unzip and extract the file from inmside and that is the one you use for uploading to the STB.
