Nfusion has all the channels except 674 indus music 678 indus vision These 2 channels are not coming on nfusion. All other indian and pakistani channels are ok
this is a good guide if u are missing lots of channels, but u can still do mannual scan..
First turn off the "TP Auto update". then setup your LNB to universal with frequency 9750- 10600. Do a blind scan. You should and will get all the possible channels. Some of them will be repeat entries. don't worry about that. the repeat entries will go away after a power off/on. After that, if you ever need to a rescan, just do auto scan.
This solution works perfect every time. One minor inconvenience is to keep the TP update off; not a bnig deal.
