what is the message are u get under network connection how is ur setup? how are u connected to ur router? what kind of file are u using? pls reply so we can help u setup..
Thank you all for your response! I have tried to use cable modem directly and use a Netgear wireless router. I have flashed using the Rom file. My Nfusion works fine but not the Kbox. Yes I uses the current file. I have flashed several times. Can I use static internet?
Once again, thanks you all so much and have a wonderful Thankgiving!
go to menu, option network , if it says connecting problem with ur ip, one thing u can do is to plug ur kbox at same location as ur nfusion, take nfusion out and plug kbox and see if its problem with kbox or ur connection..
the other thing u can try is write down the ip adress of nfusion, and then go to k1pro , change it to same number or change the last number to 1 number higher..
don't put any ip adress here.. try it and let us know.. in either case.
