KBOX pro help
Username: Ssp
Post Number: 118
i add the freq 12033,12063
on 118' dish, but no signal please help how to get the signal ,thanks
Username: Nydas
Post Number: 16654
Please tell us, if you have a 33" dish, a special LNB for 118, and if so, did you set it to 10750 and did you see green at the bottom and did you try "Blind Scan"?
Username: Ssp
Post Number: 119
i have 33" dish & special lnb. i scan indian ch like b4u music ,b4u movie sony max & work great, i want to scan freq 12033,12063 for other ind ch.thanks
Username: Pannu16
Post Number: 901
there is a problem with bin 211 onwards!! So u gotta use 203 bin and do a blind scan and then put 213 in and then put 203 back to watch channels again!!
Username: Nydas
Post Number: 16665
You could try BIN 214 and see if it will do the job.
Username: Ssp
Post Number: 120
i tried 203,213,214 but no green signal
Username: Nydas
Post Number: 16676
Do a system restore, followed by a load from USB of 213 or 214, followed by a scan of the sat.
You may switch off in between as often as it takes to get the system running well or till your fingers ache from using the remote.
Username: Nydas
Post Number: 16677
If that fails load the factory BIN 176 using loader and then start all over again as suggested earlier.
Username: Saqeeb9000
Post Number: 6289
sp you need to move ur dish slightly in order to get all thec channels,
which channels are u missing what are names of those channels,
just move ur dish little bit and u will be able to see those channels...
