What is going on with K-Box Prodigy?
Username: Ragi48
Flushing, New york Usa
Post Number: 50
K box seems to be acting up. Some times it is on and most of the times it is not. The Khub light is red. I had the Kbox going on 17th sept.(Thursday) with the new activation and of course intermittent freezing was a problem. But this morning I am not getting any channels. May be the server? Can some body advise me of the situation and thanks in advance.}
Username: Jayson
Post Number: 403
Reset your internet connection and your kbox from back button...then wait...
Username: Ragi48
Post Number: 51
Thanks Jayson:
I did all those tricks but to no avail!!!!!!!
First of all I would like to know if Kbox is on or not?
Username: Sump
Post Number: 304
yes on !!
Username: Pulpfiktion
Post Number: 482
Whiskey
Username: El_tora_the_great
Post Number: 59
U lookin for truble....
Username: Picanha
East LA
Post Number: 711
Username: Sump
Post Number: 314
yes i have experienced more reboots in last few days also ..
my tin foyal helmet came loose i think !!
Username: Sjain80
Post Number: 187
I am having the same problem. I was watching TV without any prolbems on the 17th as well. but all of a sudden my internet modem goes bad. I have changed two modems but my KHub won't work. It is on red light. I have reset kbox..reloaded factory bin and then new bin. It goes smooth upto here but when I try to upload khub activation file, it won't work. I get the error message "can't communicate with khub.check connection." IF I take the ethernet cable out of khub and then do upgrade, it works. but as soon as I connect the interenet, light goes red again. I have tried everyhiing. can anyone suggest something. I am frustated now..thanks for the help..
Username: Sump
Post Number: 342
try to load the 1.25 file first
also what box are u using and what hub
Username: Sump
Post Number: 343
file is here both version pro and Plus
http://www.kboxforum.com/forums/forumdisplay.php?f=24
Username: Sjain80
Post Number: 188
I have first loaded the 1.76beta file. and then loaded the 203 file. both were done without a hitch. but then I tried loading khub activatin file and got can't communicate error. after that I unhooked the ethernet cable from the khub and tried loading, it worked but as soon as I connect the cable, it stays red..
I am using kbox pro and khub just says k-hub.
Username: Sump
Post Number: 348
BLACK khub right? if yes then ....
try the above post use
1.25(p) first this is OLD default file like factory default
then do the normal setup
last you may need to do the hub with the loader, a computer and a serial cable
Username: Sjain80
Post Number: 189
I looked up the k-hub at ebay and it looks like K-Hub Version 2. I think my khub has gone bad..
Username: Sjain80
Post Number: 190
I tried using 1.25_up(p) file. But I am still getting the can't communicate with the hub error. I reset the kbox and first file I tried was 1.25p..same result..
Username: Sump
Post Number: 351
that may be true ..
one more thing to try, u need serial cable
Use the black serial cable (null-modem, all null modem cables are not black) for K1 PROdigy receivers.
use the loader program ...and try and reflash the hub that way .
