Nfusion hd, no signal to tv
Username: Billybobo
nfusion hd brand new, cannot get signal to tv, so I can't do anything with it, I'm sure its hooked up right. I have a nova & it works fine. need help thanks.
Username: Plymouth
Post Number: 10207
billy boy
Are you able to get SD channels or you get nothing?
Are you able to scan the channels?
Put the latest bin and don't use the proxy but HCDP, copy the settings from your Nova.
