Toroidal 90 Dish
Username: Satuser45
Has anybody installed a T90 Dish and succeeded in alligning it? a T90 Dish ia about 38inch and can hold up to 16 LNBs.
I am only setting up for 97.0W and live at Zip code 27262Upload
Username: Riconissan
Post Number: 1662
Good luck with that. I have no experience with it but it looks like it would be a pain to setup for more than 3 birds. I would rather use a motor.
Username: Pannui6
Post Number889
Im not that bright so i cant shed no light.
Username: Plymouth
Post Number: 10066
Bwenge Ruhamanya
List the satellites you want get with this dish.
Username: Chumley
Post Number: 424
Username: Pannui6
Post Number889
Post Number: 9
You guys are really smart. Nannu Nannu im Pannu
Username: Plymouth
Post Number: 10067
Bwenge Ruhamanya
If you want know how setting this dish, list the satellites you want get.
Username: Chumley
Post Number: 425
Yeah ... I wonder what he means by... I am only setting up for 97.0W
please clarify...
Username: Last_supper
Nazerith , Isreal
Post Number: 55
Gee!! I wish I was as smart as Plymouth
Username: Gregraf
Post Number: 3106
Plymouth started at a young age.
Username: Plymouth
Post Number: 10068
Cumley
A guy who buy this kind of dish don't put only one LNB.
No need to be very bright for know it!
Poor idiot!
Username: Satuser45
I started with 3 Sats in mind, 91.0W to 121.0W and did not work for me, tried 97,110 and 119 that either did not help, finally I am trying a single sat.
Still getting good signal 80% but quality is zero%.
Username: Jay_w_grayson
Prague, Oklahoma USA
Post Number: 644
Bwenge Ruhamanya, here are your settings for Galaxy 19 at 97.0°W
Try to use only one Lnb, make sure it's a
Linear LNB and pointed to the center of your Dish.
Username: Plymouth
Post Number: 10069
Bwenge Ruhamanya
Considering you will add 82W later and 121W, you have 39 degree, you put the 97W LNB 3/4" on right center of bracket when you are in front of dish.
The Skew(LNB Rotation) is the first setting to do then the elevation and the Azimut in last.
You can use the setting posted by FTA TESTER
With Lyngsat .com take the higher Tp setting, it will be easier to found the satellite, higher is the Tp, higher is the signal.
Be sure that your mat is perfectly right.
Post Number: 1667
Like I said above. You are so limited with this dish. FTA Tester gives you useless information only for one bird. I can get one satellite with a pie plate and a $20 LNB.
