Silver Member Username: Bazuka2020Post Number: 734 Registered: Oct-05 | On a side note, I was recently privy to certain information which leads us to believe that a fix for the new system may be released in the first week of July. As usual, it will be released as freeware. Rumour has it that Sonicview and C**lsat will be the first brands to release fixes however this is all only a rumour and may not even be correct at all. There is however a lot of money and many individual's resources invested in developping a new fix, it will come. Some small underground group may have already cracked it and are simply awaiting the time to be right before releasing it. |
Gold Member Username: PlymouthCanada Post Number: 9798 Registered: Jan-08 | Few rumors says Viewsat and Captiveworks |
Platinum Member Username: NydasPost Number: 15301 Registered: Jun-06 | When nobody knows anything rumours abound |
Gold Member Username: LolPost Number: 1454 Registered: Sep-06 | hows that Viewsat working there Plymouth |
Gold Member Username: PlymouthCanada Post Number: 9799 Registered: Jan-08 | My viewsat get over 1500 channels, I think it' s good |
Silver Member Username: Bazuka2020Post Number: 738 Registered: Oct-05 | Wher are those beta bins theya are talking about |
Platinum Member Username: NydasPost Number: 15323 Registered: Jun-06 | Beta testing is done by selected few individuals, and after they have reported back to the software developer, the developer would make changes and perhaps release it or ask for further testing. Major software products are put out for Beta testing by a wider user group. |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2924 Registered: Dec-06 | Plymouth how many sats are you aimed at and how many double or triple channels do you get? 1500 channels .. COME ON .. thats BS!!!! Now tell the man just how many channels are you really getting that are not doubles or triples... the truth now please |
Silver Member Username: ChumleyPost Number: 352 Registered: Dec-08 | He has over 22 sats scanned, keep in mind he doesn't watch any of those channels , they are for bragging purposes only |
Platinum Member Username: NydasPost Number: 15326 Registered: Jun-06 | In March, 2009, on a converted 2500, and a full setup for 118/119, a blind scan using Universal 2 setting of LNB, you can get about 1200 channels - that goes to one input of a DiseqC switch. A 61.5 W connected to another input gave some 120 channels. A Bev dish connected to a third input of the DisEqc gave about 400 channels. The above is based on fixed Dishes. Plymouth has a motorised Dish, an he should get over 2000 channels, if there was no Nagra 3. He also has the ability to scan some of the Sats we rarely scan. |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2925 Registered: Dec-06 | that may be true WHEN all channels worked Nalin But as of today just how many work NOW! I believe that was what Paul meant when he asked Plymouth .... Posted on Wednesday, June 17, 2009 - 03:08 pm: -------------------------------------------------------------------------------- hows that Viewsat working there Plymouth KEY WORD Nalin WORKING |
Silver Member Username: ChumleyPost Number: 353 Registered: Dec-08 | http://www.global-cm.net/MPEGlistKuBandUS.html |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2926 Registered: Dec-06 | good post Chumley thank you |
Gold Member Username: PlymouthCanada Post Number: 9806 Registered: Jan-08 | Doreen Before Bev and Dn switch to N3, I was get over 2700 channels, after Bev swith over 2000 channels. I am able to get 27 satellites now but, I will install my new mat 48' and maybe get more, because in summer the f0cking trees neigbor block the signal(40 feets high). Next for me is buy a 120 cm motorized dish and get few C-band channels. |
Platinum Member Username: NydasPost Number: 15327 Registered: Jun-06 | Doreen: Your head is sunk in KU which is now mostly mud. However, Plymouth with his larger motorised Dish is scanning a lot of True FTA. Therefore, viewing 1500 channels is quite a realistic statement and probably an understatement. Q.E.D. |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2927 Registered: Dec-06 | LOL ... I understand about the trees I have 70 trees next door... Thinking of getting some copper nails and sneaking over some night when they are out Why so many sats? most are the same with same channels maybe a few more or less... C-band .... what after the Nagra 3 fix ? Will they all still work? |
Gold Member Username: DoreenakadjOntario Canada Post Number: 2928 Registered: Dec-06 | what ever Nalin.. like i said most sats have the same channels on them. Just some have more. |
Bronze Member Username: FerozNew york, New york U s a Post Number: 59 Registered: Aug-06 | i have a few trees and i would b very hot if someone used copper nails no offense meant |
Gold Member Username: RiconissanPost Number: 1337 Registered: Feb-09 | Copper nails take too long. I got the good stuff. |
Gold Member Username: PlymouthCanada Post Number: 9808 Registered: Jan-08 | Doreen It' s not 2or 3 trees but a forest around me. On C-Band you can get all special Events like Nascar and many other then it' s totally free. Now you can get C-Band with a 36" dish. |
