Username: Kellergirl Orlando,
FL
Post Number: 162 Registered: Sep-07
Thursday, May 21, 2009 - 15:18 GMT I have scanned several different times, and I am missing about 20 channels from 110 and 119. What am I doing wrong? Thank you.
FL
Post Number: 163 Registered: Sep-07
Thursday, May 21, 2009 - 15:47 GMT Ugh, never mind. I appreciate your help Plymouth, but my box is ALL screwed up. The sat was gone again, and I had to re scan 110 and 119, and ALL the channels say PROG. UGH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I am ditching this box and getting another one.
Username: Joeturn Post Number: 555 Registered: Apr-06
Thursday, May 21, 2009 - 16:00 GMT its the files
FL
Post Number: 164 Registered: Sep-07
Thursday, May 21, 2009 - 16:14 GMT So should I re-load the bin?
Username: Plymouth Canada
Post Number: 9321 Registered: Jan-08
Thursday, May 21, 2009 - 19:08 GMT Kellergirl Do a total factory default then load the factory bin from captiveworks.com then the latest bin. Note that is possible you lose some channels with a scan because Dn had doing many change and few channels are lost.
FL
Post Number: 165 Registered: Sep-07
Thursday, May 21, 2009 - 20:19 GMT Well, just a few I am missing is Baby First and VH1, among others. And I had them yesterday. I will try that Plymouth, thank you.
FL
Post Number: 166 Registered: Sep-07
Thursday, May 21, 2009 - 21:20 GMT Plymouth, you are the man! It worked, many thanks!!!!!!!!
Post Number: 9324 Registered: Jan-08
Thursday, May 21, 2009 - 23:43 GMT Kellergirl I' m so happy for you and your husband. You are Welcome!
