Bronze Member Username: KaanwalOnt Canada Post Number: 94 Registered: Sep-08 | Can someone tell me wat is STB and where can i find it on fortec remote. |
Gold Member Username: PlymouthCanada Post Number: 9161 Registered: Jan-08 | kaanwal ali STB is Satellite box, on a multifunction remote you can fount it, but on a cheap receiver without it, you can found "Power". |
Silver Member Username: JoeturnPost Number: 388 Registered: Apr-06 | They have mislabled it, it says TV/SAT its the fifth button down counting the red one just below the number seven. SAT is Chineese for STB! One click TV two click STB http://www.alibaba.com/product-gs/224256848/Satellite_Receiver_Remote_Control_fo r_FORTEC/showimage.html glad I could help |
Bronze Member Username: KaanwalOnt Canada Post Number: 96 Registered: Sep-08 | Plymouth thanks for telling my box is cheaper next time i will try and but the expansive one!!!!!!!!! |
Gold Member Username: PlymouthCanada Post Number: 9168 Registered: Jan-08 | kaanwal ali I never say it, on viewsat if you buy a Ultra, you can have a multifunction but on Ultra Lite you can't. I don' t have your model and can' t comment on it. STB is not sat in chineese like idiot joeturn says. |
Silver Member Username: JoeturnPost Number: 397 Registered: Apr-06 | Soo sorry! King Tape Worm has advised me in a high level disscusion that it is refered to as SAT TOP BOX and the chineese were correct in its spelling my bad Me and Tape talked for hours!! We labled this hightec conversation"The King and I" plus or minus 15 days |
Bronze Member Username: KaanwalOnt Canada Post Number: 99 Registered: Sep-08 | Thanks Plymouth and Jeoturn |
Bronze Member Username: KaanwalOnt Canada Post Number: 100 Registered: Sep-08 | i m sorry its JOETURN |
