No audio or video Viewsat
Username: Way2smart
Www.Desifta.com
Post Number: 1733
No audio or video viewsat, signal are good
using 090501U file
Username: Plymouth
Post Number: 9111
The $mart 1!
Load the factory bin from viewsatusa.com, not from ftabins, because it's a old file then load the bin from ftahq.com like Rico says.
All viewsat work fine
Username: Runescaper
Yo im getting the same problem
except now im not getting any signal either
also i have this problem since like june 2007
but i was to lazy to fix it.
kk i have viewsat (silver box) and all channels use to work but then all stopped working except echostar3(indian channels) and echostar7(english channels) work but u gotta wait like 20mins per channel to make the signal load up
now im getting sick and tired of this problem
u knoe how to fix this ply?
also like the Smart one said
i had the same problem but i did a hard rebot and then it stopped showing signal on both bars..(S bar and Q bar)
-Dan
Username: Bernardmi
Post Number: 436
You are cross-posting Dan !
Username: Plymouth
Post Number: 9130
Da boi
Do a factory default, load the factory bin , then the satellite info from viewsatusa.com then load the latest bin from ftahq.com.
Blind scan then autoscan all your satellites.
Be sure that your satellite antenna setting is right.
@outer limits
soz im new to this =|
and plymouth..dude i have no idea wat u mean.
so first i do a factort default, then i load a factory bin..plz send me a link as i dont knoe much about this stuff. and statellite info?
im really sorry for troubling u. i dont really knoe much about this stuff...
Username: Riconissan
Post Number: 829
text/plainUpload
viewsatbible.txt (18.7 k)
Username: Plymouth
Post Number: 9136
Da boi
List your receiver model and I will give you the direct link.
Username: Chumley
Post Number: 160
boi , the only way you will learn is to join a real site and read a setup guide for your receiver
Username: Plymouth
Post Number: 9137
Chumley is a idiot from another site here for put down this site.
i think its called viewsat platnum?
how ever u spell it.
and thx rico for the bible thing lol
ima read it :-)
and chumley..stfu
Username: Plymouth
Post Number: 9139
Da boi
Download these 4 files, unzip it open the loader then load it in then load it in receiver.
Loader:
http://viewsatusa.com/Loader_v1.exe
Factory bin:
[link removed]
Satellite info:
[link removed]
Latest bin:
[link removed]
Now go in menu, installation, antenna setup then scan your satellite with autoscan
and chumley..stfu
Username: Chumley
Post Number: 163
LOL... instead of boi reading and learning .. all you want is to have postings like...
" Plymouth help me... "
for the most basic tasks...
FOCK YOU
Username: Plymouth
Post Number: 9142
and chumley..stfu
Username: Chumley
Post Number: 165
Emoticons are gayy,
plymouth are you gender confused?
Post Number: 831
Plymouth,
Platinum does not have USB.
Chumley is a puss.
Username: Mmoura78
hi plymouth
i have viewsat ultra 2000. works fine w/ new bin file.
just the sat 61.5 dont work. how can i fix ? i did blide scan. but still no working.
thanks
Username: Plymouth
Post Number: 9163
mmoura78
On Echo 3 61.5W the majority of channels are gone on N3.
Username: Mmoura78
Post Number: 7
so, how can i get it back Plymouth? how can i see channels on N3?
thank you plymouth for u help !!!!!!!!!!!!!!!!!!!!!!!!!!!
Username: Plymouth
Post Number: 9171
mmoura78
The only receiver who can get those N3 channels is KBox.
Username: Mmoura78
Post Number: 8
can u chek if this one is good http://cgi.ebay.com/K-BOX-KBOX-PLUS-USB-FTA-RECEIVER-W%2fO-DONGLE-(-KHUB-)_W0QQitemZ350162516021QQcmdZViewItem
and where can i get the bin files for then
thanks again Plymouth !!!!!!!!!!!!!!!!!!!!!!!!!!!
yo plymouth
for satellite info thing
how do i open it?
like wat am i suppose to do with tht??
Post Number: 837
Da boi,
you need to load the satellite info file into your receiver the same way you load the bin file using loader 2
Post Number: 7
not be a burden but i dont know how
normally my bro did tht and he left for college..plz explain how?
Post Number: 838
Da boi,
The best thing to do would be to call your brother because he knows where your files are on your computer.
If you cannot wait for him read and follow the instructions that I posted from the Veiwsatbible above.
Do not be afraid to try. you cannot hurt the box permanently.
You need to find the program Loader 2.
If you bro used your computer that you are on now to update your box, you should be able to find it.
Post Number: 839
Da boi,
If you still cannot figure it out, post here again.
You could also try to PM joeturn. He seems to be an expert and can talk you right through. Ask him for his cell #.
Username: Plymouth
Post Number: 9173
LOL
Post Number: 845
Did you like that Plymouth?
I am here all week. You should catch my 10 o'clock show
Post Number: 846
By the way... Do you know what Indian channels are up on 61? LMFAO
Username: Plymouth
Post Number: 9176
Rico
Good show! LOL
SAB and NDTV still up
