Nalin,Plymouth Experts Help...
Username: Pat_bateman
Post Number: 37
I know that we currently don´t have a bin for 2500 to 2700 flu converted or puff or lzma you name it.... But when we do have working bins, I am having problems to watch channels, i have to do this:
if I want to watch 523, I use the remote, push the buttons channel will change but wont work, then I have to hit the radio/tv button to access the radio chanels, hit the button again and now 523 will work, but sometimes it will take a long time, sometimes I dont have probs,,, and some others I will hassle with it, Multiswithc is new,cable is working fine, signal is up to 90% or more.
quality is the same... please help is annoying... by the way is FESP working? thanks guys and as always you rock!
Username: Plymouth
Post Number: 8937
Pat
Pansat 2500 doesn't have much memory and puff ask much memory and your receiver will have few problem.
A solution who can help you is put the autoroll OFF and put the keys manualy, then it will give you more memory for the usual pogram like remote and interface.
Post Number: 38
Thank you very much It does make sense....
As always thanks for the help you rock...
Username: Nydas
Post Number: 14968
You can reduce the load on the memory by deleting channels you never watch.
Username: Plymouth
Post Number: 8965
Good point Nalin!
Username: Chumley
Post Number: 120
You are welcome
