Question About Fortec Star Lifetime
Username: Jeydee
Post Number: 18
Someone gave me a Fortec Star Lifetime but i can't find a way to do a blind scan like i used to do with Pansat 2500. Is there anyway to do it with Fortec?
Username: Plymouth
Post Number: 8786
Jey Dee
Put the Tp manualy and scan it.
Use your Pansat and copy it on fortec.
Username: Jeydee
Post Number: 19
My Pansat is not working anymore so i can't opy to Fortec. So there is no other way except to put everything manually??? I can scan about 40 satellites with my BUD, gonna take an eternity.
Username: Plymouth
Post Number: 8788
Jey
Nalin can answer you.
You must convert it to puff
Here s the files:
http://currentbins.com/ftafiles/
Username: Dimwitt
Post Number: 1242
The receiver's POWER SCAN feature provides a Blind Search function enabling the user to find all broadcasting channels transmitting from the satellite
Username: Doreenakadj
Ontario Canada
Post Number: 2762
http://fortecstar.com/Estore/store/Assets/userguide/82-userguide.pdf
Username: Nydas
Post Number: 14869
If you have a Lifetime Ultra (FLU) then the only way you can use it is as a complete FTA receiver, or after converting to LZMA-PUFF and installing the latest 211 BIN, you are using it as a Pansat 2700 workalike and you will have Blind Scan.
Username: Punjavi_doo
Post Number: 253
yes, and quotations are often taken from primary sources such as personal diaries or interviews. The problem with such sources is that they may not be fully representative of an individual's views. It may be that they changed their views throughout their life, or held conflicting views at once.
Username: Jeydee
Post Number: 20
Thanks for the help guys, i appreciate it.
Ontario Canada
Post Number: 2763
i know Nalin and don't worry I have been ignoring him
