Signal disappears 10 secs after boot up
Username: Dchorseshoe
it was working fine for 1 yr and today signal will not hold after boot up i have a signal for 10 secs then it disappears i went to menu and check settings and its all fine its like i fades away tried loading virgin bin same thing....why is it doing that .........i do hard boot have signal for 10 to 15 secs then it disappears??????
danny
Username: Saqeeb9000
Post Number: 4677
which rec?
u might have a switch problem
or ur dish is moved more likely switch
replace ur switch that will solve the problem..
have sv8000 hd i tried changing the diseqe switch same thing.....i have power ever thing looks fine just signal disappears 10 to 15 secs after hard boot............it was working for a yr everthing is tight............ was working last night turn on this morning and no signal.......did a hard boot had signal for 10 secs then gone tried installing new bin same............??????????????????
Post Number: 4679
bin doesn't help may be ur settings are wrong
put all ur settings here..
