hi playmouth or nalyn plz if u can help me i downloded the new bin to my converted 25500 to 2700 pansat but no pic no file i had bin 209 it was working fine but every thjing just stop plz give me a details about where to go and wat to do to fix my pansat plzzzzzzzzzzzzz
hi sorry man plymouth i was in rush thats y anywys i have pansat2500 converted to2700 i had bin209 loded to my pansat it was working fine but 2 days ago it stop working now i downloded the new lazama 211 bin to my pansat but no channels and itried every thing dont no wat to do plz help me okay thanx and sorry if i misspell ur name okay thanx and i will wait for ur answer
thanx for ur help hust wondering the fwank7 lzma v211f emu is the right bin for converted pansat? and wen i did that it say english then there is no other option to set defalt keys or do 8282? wat i'm doing wrong?
For a person here for the past three years you are showing big gaps in knowledge. There is NO requirement that you have the right keys to be able to do 1. User setup. 2. Dish setup. 3. Antena setup. 4. Scan
The way to do "Set Default keys" is: Menu/Cas (i.e. second line of menu) then do "set default keys" and Exit.
If you're referring to me, i didn't post about needing the right keys to do anything.
zia rehman Post Number: 77
I thought zia loaded the bin and ended up on the language screen (english) and was unable to enter 8282 or go to the cas menu that I assumed was in parental control.
thanxx for all ur help finally i got my pakistani channels but wen i try to scan on echo7ku or echo 8.10 no channelsi went through with all the options u guys told me to do it i did that but no local or ppv i cant see any thing i did the tp scan /blind/advance/ i change the keys too but no luck i dont wanna lose my paki channels i'm watching those but why? i cant download the local channels? can any one help me plz
i check my antenna setting its same as i used but my question is i never had that problem before but why? my desi channels are working and no american channels and plz let me no wat is port? and where to check it? thanx plymouth
hi plymouth sorry man keep bothering u..okay i have my dish on standard all the time i tryied dp too but no channels just tell me is local american cahnnels are working on this bin or not and wat do do to get those channels plz thanx again
hi plymouth thanx man anywys i tried the blind scan too but no luck can u plz help me in detail plzzzzz i cant see nay local tv ony i can watch desi channels
hi plymouth i did every thing u told me man but i cant scan any csannels i did downloded the bin211-v3 but still no luck...my dish is working fine on desi channels but wen try to do the scan for echo7/ echo8.10 i there is no quality... i have two dishes one for desi and the other one for american channels indian channels are working fine on echo 3 and echo7 but wen i switch to scan the echo7 or echo8 for ppv and american channles nothing is happining dont no wat i'm doing wrong i did the blind scan/ tp scan / advn scan/ but nothing is working can u plz explain me in detail where to go or do wat ?
