Here is the instruction for put PID on your receiver.
Username: Plymouth
Post Number: 8244
Viewsat:
go in channel scan , arrow up then Ok then select the good Tp and with F4 on remote enter 3 pid numbers then OK then Exit.
The channels added are called Userchan-0,1,2,3,.
CapyiveWorks:
CW600P
Menu
Installation
Manual search
Advanced
Choose the good satellite then good Tp then put the 3 PID number and arrow down on last Pid and you put nothing and press OK then Exit.
The channel for me is call TVCH 125 which you can rename.
Sonicview:
Menu installation, channel Search, press Add PID(color button on remote) then put all PID number and OK Then Exit.
If someone know how put the PID on Pansat, please post it here.
Here is a refresh of channels available on Echo 3 61.5W put that manualy in PID:
AAGTV=TP12661MHz(V) Vid(4898) Aud(4899) PCR(4898)UP!
ARY one world =12661MHz(V) Vid(6434)Aud(6435) PCR(6434) UP!
PTV Global=12326MHz(H) Vid(5666) Aud(5667) PCR(5666)UP!
QTV=12661MHz(V) Vid(4130) Aud(4131) PCR(4130) UP!
Musik=12661MHz(v)Vid(5922) Aud(5923) PCR(5922) UP!
GEO NEWS=12384Mhz(v) Vid(5154) Aud(5155) PCR(5154) UP!
ETC Punjabi=12355Mhz(H)Vid(7714) Aud(7715) PCR(7714) UP!
NDTV=12326Mhz(H)Vid(7714) Aud(7715) PCR(7714) UP!
SAB=12326(H) Vid(6946) Aud(6947) PCR(6946) UP!
SAB=12471(H) Vid(6178) Aud(6179) PCR(6178)
Sab is on both Tp
Username: Hi09
Post Number: 91
okay so tried this on a viewsat extreme
PTV worked...
QTV is playing a video of some guy saying i am receiving un authorized channels and here is how to order
the rest just say no audio or video...
any advice?
Username: Satgrl
Dil Mei DarD a Jaga ...
Post Number: 1594
OK HERES THE PROBLEM ON MY SONICVIEW 4000 there is no option for CHANNEL SCAN OR INSTALLATION... Instead i go to MENU DISH SETTINGS AND THERE IS NO OPTION FOR ADD PID???? THE COLOR BUTTON ON REMOTE ONLY ALLOW U TO satellite scan tp scan blind scan and scan all..then when i got to channel setup it only allows me to delete rename channel or favortite thats it...pretty confusing i tried searching for the past hour...no luck any help?
Username: Wonderplanet
Post Number: 15
Plymouth What about Pansat 2500 to 2700? Can you tell the instructions for entering the pid for that receiver too?
Username: Plymouth
Post Number: 8246
Satgrl
I had read your SV manuel and this is what I had see.
Menu, menu installation, channel Search, press Add PID(color button on remote) then put all PID number and OK Then Exit.
Username: Plymouth
Post Number: 8247
BooyakashaZuloo
All channels are Up for me with those keys.
Go in menu, User setting, Optio 2 then put the Auto Tp "off"
Username: Kaanwal
Ont Canada
Post Number: 65
Thanks Plymouth for starting this thread, can someone please post the info
that how will we add the pid in fortec lifeitme ultra,
Thanks
Username: Plymouth
Post Number: 8248
Wonder
I don't have this info for Pansat if someone can put it on this thread that can be appreciated.
Username: Plymouth
Post Number: 8250
please download your manual on the manufacturer sites as for sonicviewusa.com, viewsatusa.com, captiworks.com.
Thanks
Username: Satgrl
Post Number: 1597
no plymouth that is not correct but i figured it out..u go to menu installation click on tp and then the list comes up and then u click add tp with blue button...well i did all that changed the VID AUD PCR thingy after that i clicked OK and it says save and u could rename it or something...AFTER THAT i dont know what to do am i suppose to do tp scan? thats what i tried but when i scan those channels still dont come the name i saved it as it comes up in the channel scan BUT when i save and exit that channels not thier im freakin confuseddddddddddddddddd..lmao..help help
Username: Kaanwal
Ont Canada
Post Number: 66
http://www.dvbresource.com/receivers/fortec_lifetime_ultra/fortec_ultra_menu.htm l
This is the manual for forteclife time ultra can some one tell me the steps to get those channels , i know how to add the ,tp, vid, aud and pcr can someone tell me wat sud i do after adding their values i will appreciate that.
Username: Plymouth
Post Number: 8251
Satgrl, kaanwal ali
first it seems that we need to put the auto Tp "off"
No scan is needed for get those channels.
Note that the channels have any name you must rename those channels.
Now I go to sleep, this 2 days give me some work.
Good Night!
Username: Satgrl
Post Number: 1598
what do u mean the "channels have any name u must rename the channel"?? ok so we dont scan but we just turn TP off correct? and then we change the PID thingy VID AUD PCR then we just go to the channel and it will work?? ok ill try it thanks ok
Username: Harjun
Post Number: 63
hi i have viewsat pro i tried to put all pid number but the channels are not coming also i did so many time auto scan
Username: Ratna1234
Post Number: 12
Plymouth, Any information on Viewsat MAXHD ?
Thanks
Username: Plymouth
Post Number: 8255
Ratna
Check in your user manual at viewsatusa.com
Username: Nidz
ohh plzz somebody post how to put PID in pansat
Username: Hamzazaid
Post Number: 8
I think you put in advanced scan because i got PTV that way. But for some reason it says scrabled or bad.
Any suggestions Plymouth
Username: Dimwitt
Post Number: 1181
Try reboot the receiver, these channels have no $ sign and should not be scrambled - they come in on a pansat 3500 with '06 bin
Username: Nidz
@z..i tried doing everything but no luck man i mean i did everything i got no channel not even PTV and am using pansat 2700A if u know anything how to get any desi or pakistani channel in pansat 2700a plz tell me that wud be great help man i soooooo wanna watch TV
Username: Hamzazaid
Post Number: 9
For some reason the channels r comming up as 0000.
But i rebooted and still scrambled and bad.
Its true they have no $ sign.
Tooter you know what i am doing wrong?
Username: Dimwitt
Post Number: 1182
This is what I did with a 3500- i believe the menu is the same as the 2700
menu - installation - advance scan - select satellite press OK-
using volume on remote select the down frequency- 12326
go down to vid pid and enter 5666 - audio enter 5667 - pcr enter 5666
select TP scan and it should scan one channel -CH-A
Suppose you could also give the channel a name on that same menu page.
Username: Sonia18
Post Number: 40
I also need help for Pansat does anyone knw how the channels will come for pansat?
Username: Nidz
thanks tooter :-)
i did as u said but it says scrambled or bad channel nothing is showing except this scrambled or bad channel i am realy tired LOLZZZ
Username: Plymouth
Post Number: 8259
nida cha
Try to put the auto TP "off"
Username: Hamzazaid
Post Number: 10
Sonia go to installation then advanced scan. Then find a good freq that has quality. Then put in the PID values(Audio, Video, pcr values) name the channel and scan. (If you dont name the channel, the channel will come up as CH-A.)
Hope this helps!
Username: Hamzazaid
Post Number: 11
Tooter
When i scan with down freq of 12326 i get no quality and so i get no added channels(I did put in the PID values)
But if i scan (Putting in the PID value)with a freq of some other number that does have quality i get the channel but the channel says scrmbled or bad.
And i also have autroll off.
What am i doing wrong?
Username: Satgrl
Post Number: 1602
i tried that in SV and when i scan the cannel i name it as comes up in the scan..when i exit and save the freakin channels not there any help guys???
Username: Sonia18
Post Number: 42
Thx Z i did that and i'm getting aag ..but the thing is when i did it on aryonewo then i lost agg i even saved aag on a fav thing but it styll went away how can i keep all of them??
Username: Nydas
Post Number: 14651
After saving it as favourite, you should rename it to the new name.
All special scans are first named CH-1 by the software, an a new special scan will overwrite this name, unless you change the name soon after scanning.
It is usually convenienct to do a alphabetic sort, so you can find the new channels under CH-1 and then RENAME it.
Username: Hamzazaid
Post Number: 13
Sonia
No Problem
What freq did you use 12661 or Any random one that had quality?
Username: Valinex
Post Number: 48
All the arabic chanels have disappeared. Are they gone for ever to N3, or can I get them through PID, and how ?
Username: Sonia18
Post Number: 44
Z
i used 12661 .. can i use any? because m getting the rest except qtv and aryw
Username: Sonia18
Post Number: 45
Z
Username: Hi09
Post Number: 92
hey Plymouth tried turning AutoTP off too but niothing... so here is my situation
i created teh new channels with F4 PTV is working great, QTV channel has the video of the guy telling me i am stealing and how to order
the rest just say no audio vidieo.. BUT the original QTV IS WORKING.. its 6## something cant remeber but nothing else works at all...
any advise? please
i want to get ZTV ATN Indus and GEO backup and running.... much appreciated...
Username: Plymouth
Post Number: 8313
BooyakashaZuloo
You can try it: delete all 61.5W channels and try to put PID and rename the channel, do it for all channel added.
If it work now do a autoscan with Auto Tp OFF
Username: Aam245
Plymouth
I have SV8000HD . First of all there is no channel search option after Menu,Menu Installation, its only channel edit option which does not let you edit the VPID etc and the blue button there is for channel Lock for adult lock. However If one goes to first option under Menu Installation, it opens the screen for selecting satellite and lnb type, TP, diSeq port selection etc. One can click on the TP and it opens up the TP's list where all TP's are listed and buttons on remote are enabled for editing, adding or deleting TPs. The blue button is then enabled for "Add PID" to a highlighted TP. By pressing the blue button "AddPID " option a pop up apear showing values for VPID, APID and PCR and default 8192 for all is shown. However when you try to edit those PIDs it only takes 3 digit numbers although default 8192 shown was a 4 digit value. Whereas all the needed PIDs for indian channels and others are 4 digits.
The channel search option you mentioned as per manual comes only if factory installed channels. So there is no channel search option. I am perplexed as how one can add a 4 digit PID in SV8000 HD when it is only allowing 3 digits to be added.
Username: Plymouth
Post Number: 8317
Aam
I Don't have this receiver and try to help for the best I can.
Put the factory and try to edit those channels then load the latest bin and reply with the result.
Username: Plymouth
Post Number: 8372
Bump
Username: Aam245
Plymouth !!
I tried your suggestion but no vail..VS8000HD only allow 3 digits of PIDs to be entered :-)
Username: Aam245
Besides as of now all SATs are showing scrambled on SV8000. Is it Armagadon or just something with SV8000 ???
Username: Plymouth
Post Number: 8386
Aam
Use Channels Master for put the PID number.
Username: Vian
how to set autoroll off in pansat 2500a to 2700a clone
Username: Hamzazaid
Post Number: 17
agreed with plymouth
channel master works best (only way i got my channels)
Username: Tj07
Post Number: 47
please let me know what is PID how to work for pansat 2700A where can I get????
Username: Tj07
Post Number: 49
help what is pid
Username: Sauib
if u want to put the pid in an sonicview sv 4000 here it is go to menu go to dish setting and go to transponder click ok and enter the pid numbers
Username: Rbhagwandin
Brampton, Ontario Canada
how do i add 118 sat to my 301 reciver.
Username: Cricket674
Post Number: 277
Help!!! I have read many threads but still don't know because of the numerous ways... How to get Pakistani Channels on Pansat 2700. with Nkk Mty 211 Lzma Bin If I have to load anything in my receiver what should I load and how ... I am a total noob. please help thx
Username: Kaanwal
Ont Canada
Post Number: 76
How to get GEONEWS,ARY,PTV,AAG and THEMUSIC, u can get it on echo 3/61.5
Go to Menu--a Installation-aAdvanced scana Select your satellite i-e Echo3-a
Enter these values in screen
1) Down Frequency---------12384
Polarity---------------------Horizontal
Channel Name------------GeoNW
Video PID-----------------5154
Audio PID-----------------5155
PCR PID------------------5154 -aOK
2) Down Frequency---------12326
Channel Name------------PTV
Video PID-----------------5666
Audio PID-----------------5667
PCR PID------------------5666-a
3) Down Frequency---------12661
Polarity---------------------Vertical
Channel Name------------ARYOW
Video PID-----------------6434
Audio PID-----------------6435
PCR PID------------------6434-a
4) Down Frequency---------12661
Polarity--------------------- Vertical
Channel Name------------AAG
Video PID-----------------4898
Audio PID-----------------4899
PCR PID------------------4898-a
5) Down Frequency---------12661
Channel Name------------TheMusic
Video PID-----------------5922
Audio PID-----------------5923
PCR PID------------------5922-a
6 and 7)
If u don't have "NDTV" and "SAB" in your channels list than do a blind scan u will get both of them.
Username: Aam245
Plymouth
Thanks for the idea about the channel master...I downloaded the latest version 1.20.3 from dsstester...went to the basement and pulled the oldie RS232c (null) cable I was so accustomed to using with my oldie PANSAT2500..and connected the SV8KHD with my old computer on COM port...now I tried connecting and it wont connect..also tried connecting it when SV is saying "power on" just after hard boot...wont work..I donno what to do ?? back of the box the port is labeled RS232C and it is not working somehow...
Any ideas..
p.s. note that I have the module installed and the shunt is also installed. but it shouldnt have any affect on connecting with the PC thtough this null cable..is there any different cable I should be using (the cable is null and not crossed) ??
all the help is appreciated greately..
AAM
Username: Imars99
Post Number: 174
With Pansat 2500 you should use straight cable.
Username: Aam245
yes it is straight cable..I have been using it with my old pansat...are you saying that straight cable will not work with SV8kHD ?? this is RS232C straight cable ?? so ??
Username: Nydas
Post Number: 14758
older Sonicviews normally used Null cables. I do not have information specific to SV8kHD but most likely it uses a Null cable, exactly opposite to the straight cable you are trying to use.
In order not to be confused, I suggest you buy a M/F Null adapter. Then you can try using it with your old cable or without using the the new adapator - you will get to try both straight and null that way.
Best of luck.
