OK HERES THE PROBLEM ON MY SONICVIEW 4000 there is no option for CHANNEL SCAN OR INSTALLATION... Instead i go to MENU DISH SETTINGS AND THERE IS NO OPTION FOR ADD PID???? THE COLOR BUTTON ON REMOTE ONLY ALLOW U TO satellite scan tp scan blind scan and scan all..then when i got to channel setup it only allows me to delete rename channel or favortite thats it...pretty confusing i tried searching for the past hour...no luck any help
