Lost Channels w/209 bin
Username: Jonebgood
Post Number: 13
Loaded new 209 lzma bin and lost many channels. No signal on many channels and what channels work are lost and go to a No Signal mode. Please help!!!
Username: Plymouth
Post Number: 7884
JonEBgood
Do a autoscan, if it not work put the keys manualy.
Here is the keys:
Dish Network (0101) [Last update: Fri. Feb 27, 8:07 PM CST]
86: EE 81 EF BB D8 9F 8C 00 EE 06 35 E2 1C 1B 92 58
96: FE 4C 22 B6 AE F8 17 F6 68 69 FD 64 36 87 9E A8 New
Dish Network New Provider ID (0106) [Last update: Thu. Aug 28, 4:14 PM CDT]
86: C9 DC DB 84 5A B8 2C DF 7F 32 8D E5 21 5C 45 4E
96: 4E B1 A8 DA 2D 92 90 D9 E6 3C 5E CE E4 FE E3 86 New
Username: Jonebgood
Post Number: 14
I have done this and if you had read what was typed (Loaded new 209 lzma bin and lost many channels. No signal on many channels that work and go to a No Signal mode.}This does not work. I am still looking for someone that can help me. Thanks.}}}}}
Username: Nydas
Post Number: 14555
JonEBgood:
I am presuming you have had a PUFF conversion and also had a 1.03 PUFF_LZMA boot added.
Without know details of what sat you are scanning, I suggest you add the 1.03 boot again and then install the PUFF_LZMA_209 again.
You might as well do A/R off and manual entry of keys.
Do user setup, antenna setup and rescan.
If still not successful, tell me what dishes you have and what you are scanning.
Username: Jonebgood
Post Number: 15
I have done what you suggested with the 103 PUFF_LZMA boot also with the A/R off rescan and no luck. Sats 110 & 119.
Main sw off & on, nothing different.
I have been using the 500 dish for years and a 2500A original. All this has started sense the 209 bin. Thanks.
Username: Kacha
Post Number: 63
same for me ...iloaded the 209 bin and my channels r gone as well.
Username: Nydas
Post Number: 14561
1. Check MENU/SYSTEM FOR 1.03 BOOT
2. Delete all channels.
3. Install LZMA_207.
4. Install LZMA_209.
5. User setup, antenna setup, Blind scan.
I can't think of anything else except to restart at b60 boot andwork up via PUFF BOOT and LZMA_BOOT
