Whats wrong with my receiver...help
Username: Shadow45
Mty, Nuevo Leon Mexico
Post Number: 304
ever since i loaded the P.U.F.F. v207 its been acting weird, i turn it off and it turns on by itself like an hour later...today i came home from work and i found it "rolling" the P.U.F.F. across the screen, again all by itself....any one else having to deal with this or do i have ghosts in my house?...
BTW, my system is a lavasat3200 converted to P.U.F.F.
Username: Nydas
Post Number: 14362
The following might work.
1. Note down antenna settings.
2. Delete all channels.
3. System reset.
4. Hardware reset. Switch off and on at back.
5. Reload 103 boot.
6. Hardware reset.
7. Load LZMA 207 BIN.
8. System reset.
9. Hardware reset.
10. User setup.
11. Antenna setup.
12. Blind scan one sat.
13. Make sure you can see TV.
14. Scan other sats.
