Viewsat pro v/s viewsat ultra v2
Username: Hikmatprinter
Post Number: 27
can anyone tell me what is the other differences b/w this two receivers then pvr and which one is better and newer.
Post Number: 28
anybody who can answer me about this.
Username: Plymouth
Post Number: 7304
Rahim
The both are same receiver, the viewsat pro is PVR, which you can record.
Post Number: 29
thank you
Username: Plymouth
Post Number: 7309
Rahim
You are Welcome
Username: Joel16
Post Number: 46
Plymouth,
VS 7000PVR should it take up to 5 seconds when scrolling the EPG Guide?
I get "Please Wait a minute" message. I do not have this problem on a VS Platinum.
Thanks in advance
Username: Plymouth
Post Number: 7377
Joel
Reload the latest bin file.
Is it new or it happen always?
Username: Joel16
Post Number: 47
Good morning Plymouth.
I have Loaded 090111.
I just bought this PVR7000 new 4 weeks ago. This is the first time that I have received DN guide so I am not sure if this is normal to have to wait up to 10 seconds when scrolling the guide.
I guess I can live with it until the next Bin is released. If it continues to be slow I will start a new post. Maybe the coders are unaware of this problem.
Thanks Brother
Username: Plymouth
Post Number: 7381
Joel
Good morning
It seems that the PVR7000 against the Ultra do that you have to wait until the EPG coming, on Ultra it give no information, maybe it is because it is a PVR.
You can set the good Tp in the EPG menu.
Go in Menu
User setting
0000 PIN Code
EPG Setting
On EPG TP E: put 12472
Now on top you can see Receiver Guide, Press OK and wait then exit.
That will be work now
Username: Joel16
Post Number: 48
Cool,
I will try that when I get home from work.
Thanks to Plymouth PhD
LOL
