Bronze Member Username: Ehsankhan777Post Number: 52 Registered: Jun-06 | I had my dish installed yesterday 119 and 110 is working fine but 118 I can scan and see the channels but when I go to view the channels it keeps processing autoroll dish settings standard lnb on 10750 11715 TP port 2 appreciate any help with this. |
Silver Member Username: XtrawestCanada Post Number: 240 Registered: Nov-05 | port should be same for both 118 and 119 if ur using single lnb for both directions |
Gold Member Username: PlymouthCanada Post Number: 7261 Registered: Jan-08 | Ehsan Khan List the LNB Type: Try on OCS-DP or Universal High: 10750/ Low: 9750 and see if it work. |
Bronze Member Username: Ehsankhan777Post Number: 53 Registered: Jun-06 | I have the new 118 dual lnb for the super dish 33inch. with a dp34 switch installed. I did try universal but didn't get anything.I will try OCS-DP and will also try the same port as 119. Thanks |
Gold Member Username: PlymouthCanada Post Number: 7264 Registered: Jan-08 | Ehsan You must use Universal High: 10750/ Low: 9750 Try it: Go in Menu System information Code Menu Select Nagra Down arrow then select 00 01 00,01 01 00 and 01 06 00 and delete those 3 dish provider with "F3" on remote exit and save then load the latest bin file, save and exit, wait on a channel until the autoroll found keys. It will take 5 to 15 minutes. |
Platinum Member Username: NydasPost Number: 14232 Registered: Jun-06 | Since this is your first scan of 118, I suggest you keep autoroll off and scan with appropriate port conection, and LNB type Dishpro or OCS-DP. |
Gold Member Username: PlymouthCanada Post Number: 7266 Registered: Jan-08 | Nalin It's not a DishPro, because he says a 33". Sometimes Viewsat Ultra is blend with the ports and deleted provider work. |
Bronze Member Username: Ehsankhan777Post Number: 54 Registered: Jun-06 | Plymouth, I tried these settings still did not get anything still say's autoroll processing. Should I delete all the channels and then try it again?I even changed the port to the same one as 119 and didn't work |
Gold Member Username: PlymouthCanada Post Number: 7270 Registered: Jan-08 | Ehsan Go in menu, installation, channel scan then delete the satellite with garbage can exit and save then return in antenna menu, do setting then do a autoscan and a autoscan, now return in antenna setup and be sure that your settings is right. Reply with the result. Which LNB model? |
New member Username: Bandino52Post Number: 1 Registered: May-08 | i have installed super dish with dp34 switch with 110, 118, 119 sat,i am getting all indian chanel except zeesp #576. my riciver is vs ultra , please help |
Bronze Member Username: Ehsankhan777Post Number: 55 Registered: Jun-06 | OK I asked the guy he said that it is the superdish with dp34 switch with 118,119 and 110 lnb toward the right side. lnb port 1 118 lnb port 2 119 third separate lnb is 110 which i think is circular for 110 |
Bronze Member Username: Ehsankhan777Post Number: 56 Registered: Jun-06 | Bharat, Can you please give me your dish settings and if you changed anthing after installing the super dish |
Gold Member Username: PlymouthCanada Post Number: 7271 Registered: Jan-08 | Ehsan Set your LNB Type: OCS-DP and legacy switch in antenna menu on SW-21, try dish 1 and 2 |
Silver Member Username: Jay_w_graysonPrague, Oklahoma USA Post Number: 398 Registered: Jul-08 | Ehsan Khan Bronze Member Username: Ehsankhan777 Post Number: 55 Registered: Jun-06 Posted on Wednesday, January 28, 2009 - 09:19 am: -------------------------------------------------------------------------------- OK I asked the guy he said that it is the superdish with dp34 switch with 118,119 and 110 lnb toward the right side. lnb port 1 118 lnb port 2 119 third separate lnb is 110 which i think is circular for 110 Hey...Ehsan Khan, maybe this picture will help some. Standing in front of your Dish. |
Platinum Member Username: NydasPost Number: 14240 Registered: Jun-06 | Bharatbhai: All the Indian channels are coming from 118 - Anik F3, except that the ZEESA - 576 is on Echo 7, at TP 12516 (V), SR 20000. If you are connected properly for 119W (Echo 7) you either have already scanned it or will get it by scanning the appropriate TP mentioned above. |
Bronze Member Username: Ehsankhan777Post Number: 57 Registered: Jun-06 | Nalin this is what I have except for the 129 lnb I have 118,119 and 110. If you have any thoughts why it's not working would be appreciated. I want to thank everyone so far for there inputs on this issue. |
Gold Member Username: PlymouthCanada Post Number: 7272 Registered: Jan-08 | Ehsan Is it a new installation? The Dp34 and DN LNB not work well on Viewsat |
Bronze Member Username: Ehsankhan777Post Number: 58 Registered: Jun-06 | what would you suggest. and yes it is a new installation |
Bronze Member Username: Ehsankhan777Post Number: 59 Registered: Jun-06 | Nalin, My issue is that my receiver keeps auto roll processing after I added 118.7 sat to vs ultra and after i got the dishnetwork plus receiver and lnb in the picture above. |
Platinum Member Username: NydasPost Number: 14244 Registered: Jun-06 | Did you try scanning with autoTP off? |
Bronze Member Username: Ehsankhan777Post Number: 60 Registered: Jun-06 | I tried it keeps saying autoroll processing even with tp off here are my settings 118 lnb power on universal 10750 high port2 |
Bronze Member Username: Ehsankhan777Post Number: 61 Registered: Jun-06 | Bharat Patel, Since you have the same receiver and same dish + lnb can you please give me the settings that you have for sat 118 |
Platinum Member Username: NydasPost Number: 14250 Registered: Jun-06 | About Inidan/Pakistani/bangali channels - see this. https://www.ecoustics.com/electronics/forum/home-video/547535.html |
