Silver Member Username: JuanchoCANADA Xx Post Number: 449 Registered: Jun-08 | C/P plus the boot Fwank7-PUFF-boot_Ver.1.0.3 For those that used the PUFF_VER1.0.1 boot already use this one insteads please. For those who have not used the PUFF_VER1.0.2 boot yet use this one instead also. If you already use the PUFF_VER1.0.2 boot all you have to do is. Open UkRoNiC's BOX Updater .421. Loader. Open PUFF_VER1.0.3 bin into Loader. Turn receiver ON and " LET RECEIVER FULLY BOOT UP TO ON or CHANNEL # ". Hit download on Loader. Write will complete in 10 seconds then receiver will reboot with P.U.F.F P.U.F.F. and come ON and thats it your done. Of course you will have to wait for a new bin to fix the freezing issues. For those that have not used the PUFF_VER`1.0.2 boot this is what you need to do. 1). Open UkRoNiC's BOX Updater .421. Loader. Open PUFF_VER1.0.3 bin into Loader. Turn receiver ON and " LET RECEIVER FULLY BOOT UP TO ON or CHANNEL # ". Hit download on Loader. Receiver will reboot with P.U.F.F. P.U.F.F. and will get stuck on " F. ". Turn receiver OFF from back switch. 2). Open Jvvh-Team-PUFF Loader. File, choose Fwank7_Jvvh-Team-PUFF_(Lzma)_V206 bin. Turn receiver ON and soon as you see the " P. ". Hit download on Loader. Write will complete in 2 minutes then receiver will reboot with P.U.F.F P.U.F.F. and come ON and thats it your done. Of course you will have to wait for a new bin to fix the freezing issues. When loading the V206 bin make sure it is the v206 bin that has (Lzma) in the bin name or your receiver will get stuck on " F. ". Remember i did send you two different V206 bins the right one was in the PUFF_VER1.0.2 folder. So I am attaching again the V206_(Lzma) bin you need to use or just wait for a new bin. Attached Files Fwank7-PUFF-boot_Ver.1.0.3.zip (18.0 KB, 252 views) __________________
New member Username: Cknguyen18Post Number: 5 Registered: Aug-07 | I did follow instruction, but it kept giving me ER1. Can you help me? | |
Silver Member Username: JuanchoCANADA Xx Post Number: 485 Registered: Jun-08 | use ukronic's loader 421 for the boot file and loader 1.4 for bin file 207 Lzma So if your receiver displays ( PUFF PUFF ) then you are to use the PUFF bins ONLY. If your receiver displays ( P.U.F.F. P.U.F.F. ) with dots after each letter then you are to use the bins with (LZMA) in the bin name ONLY. Just make sure it has for ex. Jvvh-Team-PUFF_(Lzma)_V207.. (Lzma) is what you look for in the bin name if you used the PUFF_Boot_VER1.0.2 or VER1.0.3 boot as loading anything else will get you stuck on " F. " until you load the proper bin to your receiver. |
Platinum Member Username: NydasPost Number: 14215 Registered: Jun-06 | bump | |
New member Username: Cknguyen18Post Number: 9 Registered: Aug-07 | Hello Juan, Thank you very much for a clear instruction. I did load successful. Thanks both Juan & Nalin. |
New member Username: Cknguyen18Post Number: 10 Registered: Aug-07 | Nalin, Are Dishnetwork and Direct TV the same? |
Platinum Member Username: NydasPost Number: 14225 Registered: Jun-06 | No, they are distinctly separate and competing networks |
