HD Sats
Username: Hockeycraze12000
Post Number: 38
What sats do i need to get all the hd channels on Dish network?
I am currently pointed at 110 and 61.5, do i need any more sats?
Username: Plymouth
Post Number: 7133
Khalid Alakoozi
With dish 1000plus: (110,118.7,119,129)
Dish Network TurboHD DISH 1000.4: (61.5A°W, 72.7A°W, and 77A°W)
Dish Network DISH 1000.2: (110,119,129)
hd channels are on 61.5W, 72.7W, 77W, 118.7W and 129W
Username: Justforhahas
Post Number: 1694
Most are on 129W satellite
Go here to see whats on which satellite for Dishnet... www.dishuser.com
Username: Nydas
Post Number: 14082
You should get the Eastern Arc setup (61.5W, 72.7W, 77W),
and/or get DP 1000+, which gives 110W, 118.7W, 119W, 129w.
application/mswordUpload
DP 1000+.doc (66.0 k)
Please remember that most of the HD channels are Nagra 3 encoded and are no accessible from FTA receivers.
Post Number: 39
ok, let me it put another way :-)
what hd channels will i NOT get if im pointed to 61.5 and 110.0,
thanks for the help
Username: Dimwitt
Post Number: 1068
It seems you would be missing about 8 ppv, CSNCA & Altitude
look here
www.dishuser.com/hdchan.php
