Viewsat 7000 freezing
Username: Jojogun
Fairfield, CA United States
Post Number: 483
My picture freezes every 10 minutes or so for about 3 to 4 minutes and then comes back in. Anyone else having this problem? I am not going to say those magic initials. ECM. I'm just gonna assume my box is out of whack.
Username: Plymouth
Post Number: 6778
JoJogun
Reload the bin file 2 times with LNB unhook.
[link removed]
Reply if it not work
Username: Jojogun
Post Number: 484
I'll give it a try...thanks
Username: Plymouth
Post Number: 6780
You are Welcome
Username: The_coders
Post Number: 1645
Username: Kb56
Post Number: 27
hey guys,
i got the 9000 model. will this zip drive work for that too? ya.. i'm gonna try it out and see, but if there is a specific version... thanks.
Username: Plymouth
Post Number: 6781
K B
NO DO NOT LOAD IT
Use this link:
Site: [link removed]
File: [link removed]
Username: Jojogun
Post Number: 485
OK, by trial and error I finally figured out the solution. My dish has a dual connector LNB and connects to my receivers (A) and (B) connectors. Well...when my son came for a visit I put my Viewsat Extreme in his room and disconnected from (B)to my 7000 and connected to the Xtreme in his room. I had figure the 7000 A and B receivers were independent of each other and if I disconnected a connection it would not affect operation. Well it worked for awhile and then the freezing started. After I connected back to A and B the freezing stopped and everything is ok. What can I say...Live and learn
Username: Plymouth
Post Number: 6793
Jojogun
Good work!
If you use a Dn DP dish which is very sensitive with voltage input.
A and B are independant so it will be a bad contact on a connector.
Username: Lubfr01
Post Number: 49
don't want to highjack this thread but would like to know if there is any such freezing fix for Pansat 2700?
