Have a viewsat ultra receiver. The remotes not working properly. Its like the batteries dying. Then if I push the change channel button it keeps changes like 15 channels. Theres brand new batteries in it. Also tried the same receiver with a different remote, same thing. help
something could be wrong with your sensor on the box make sure there is nothing covering it and it is clean. Also try moving the location of your box closer to the remote if you can.
PLEASe Help me. since yesterday , when you asked me to do a SET DEFAULT. I did it and tried to set up setting in antenna setting. BUT nothing happen. the Receiver is just Scanning,, but nothing appear in the list.. its only the % which rolling. Neither the quality showing anything. AS IF the receiver has return EMPTY as new one..
