VS Plat/Lite
Username: Smoke74
Post Number: 152
My buddy called me last night and said he was watching his sat when it suddenly turned off, turned back on and his display was saying things like 2909, blank, ----, and so on. He also mentioned that the power button on the front of the unit don't work and either did the remote. He was able to turn it off at the rear and attempted to reset but the same thing happened. He also said that the tv screen was locked on the sat radio. Any ideas?
Username: Plymouth
Post Number: 6019
smoke74
Do this , but use good files for your box.
In your package box with receiver is furnish a cable RS-232 you must download factory bin with the cable from your computer .
Go to: [link removed]
download this 2 files:
Ultra Lite Loader - Firmware Updater (also works with Ultra)you install this one on computer
VS2000 ULTRA Factory Bin File - V132
for download with the loader in your receiver
close rear switch on receiver
open program take file v131
clic to download in receiver and a second after(you can repeat it many time before it work)
switch on
the transfert take 5-10 mins
you must see 0000
download the last bin with USB
Good luck
Username: Cartier1
Post Number: 2221
PLYMOUTH IM SURE U DID NOT PAY ATTENTION TO HIS THREAD . HE IS TALKING ABOUT PLATNUM OR LIT NOT THE ULTRA LITE.
DO THE SAME THING EXEPT GET THE FACTORY BIN FOR PLATNIUM OR LITE. AND FLASH WITH THE LATEST BIN FOR LITE OR PLATNIUM .
Username: Plymouth
Post Number: 6024
Cartier i do mention to him:
"""Do this , but use good files for your box."""
Username: Cartier1
Post Number: 2223
the guy is gonna drop the ultra fil and the sky will fall
Username: Plymouth
Post Number: 6026
Cartier
Sometimes i use bad loader and files to force bin in receiver then load the good one.
Never a bad file kill a receiver.
Right the sky will fall but we can replaced it.LOL
