Atmega Help
Username: Jinnspeed
Post Number: 32
I am new to using atmega. I am using Phoenix V 2.5.9 and it is not detecting the card. Following are important points:
Card do not have jumper. Not req for phoenix loader. i am using serial port pin 3 to program atmega 18 crystal 128. I have the atmega programmer but do not know which pin will be used for programimg. I have 10pin atmega ans 3 pin atmega. For 10 pin i place all the pins into the programmer because it also has 10 femail ends. For 3 pin i use the first pin close to edge, the other two pins are without jumper, but jumper not necessary for phoenix loader
Please let me know what i am doing wrong.
Thanks
Username: Sam_patel
Post Number: 101
go to the wwww.dishgods.tv they will help you ok
