Username: Pugluvr Post Number: 1 Registered: Nov-08
Monday, November 17, 2008 - 06:04 GMT hello I can not get all the PPV channels im only getting 4 of them I scanned all ecostar can someone please help me
Username: Viruscauser Leesburg,
Georgia
Post Number: 804 Registered: Mar-07
Monday, November 17, 2008 - 07:03 GMT Need more details: What receiver, antenna Diseqc settings....
Username: Pugluvr Post Number: 2 Registered: Nov-08
Monday, November 17, 2008 - 15:04 GMT viewsat ultra lite, lnb type - standard frq - 11250 tp frq 12224 diseqc - none legasy off I have tried setting my tp to 12239 but after i save and go back it still says 12224
Username: Pugluvr Post Number: 4 Registered: Nov-08
Monday, November 17, 2008 - 15:05 GMT viewsat ultra lite, lnb type - standard frq - 11250 tp frq 12224 diseqc - none legasy off I have tried setting my tp to 12239 but after i save and go back it still says 12224
Username: Nydas Post Number: 13154 Registered: Jun-06
Monday, November 17, 2008 - 15:19 GMT PPVs are on 110W (Echo 10/11) You must post the type of LNB you have - at least the name on the LNB and the Dish.
Username: Pugluvr Post Number: 5 Registered: Nov-08
Monday, November 17, 2008 - 15:24 GMT oh im not sure what lnb i have, but its a Bell dish dual lnb I scanned all echos
Username: Nydas Post Number: 13157 Registered: Jun-06
Monday, November 17, 2008 - 15:35 GMT 1. If you were scaning Bell (82/91) and turned your dish to get DN (110/119), most likely you turned it only 19 degrees and not 28 degrees as required. Make sure you are pointing to 110/119 119W LNB type dsc-dp LNB freq 11250 DisEqC switch 1.0 - 1 First TP 12239 H Full scan or Blind scan 110W LNB type dsc-dp LNB freq 11250 DisEqC switch 1.0 - 2 First TP 12224 V Full scan or Blind scan The above settings are on the presumption that you have the Dish type of LNB used by many in Canada for Bell. You can try standard LNB
Username: Pugluvr Post Number: 6 Registered: Nov-08
Monday, November 17, 2008 - 15:39 GMT ok thank you very much i will try it
