Non 8PSK HD FTA Receivers
Username: Tooter
Post Number: 23
TP 12603 V 20000 3/4 @ 61.5W has HD channels-
positive results with 9200 and 8psk disconnected via loop out.
Username: Tapeman
New York City in-HD, NY
Post Number: 3710
I'm not sure what yor saying
Yo say non-8PSK HD FTA receivers
There are many SD channels recently loaded to 61.5 they are not HD
Username: Tooter
Post Number: 24
Trying to say,
HD receivers with out the add-on board, might be able to receive the HD channels on that TP.
Username: Tapeman
Post Number: 3712
That's what I kind of guessed
There is no MPEG-2 HD on this arc
But I did find some SD channels that are normally on 110/119
Regular receiver can do MPEG-2 doesn't have to be HD
Username: Extremex
Post Number: 238
What he is saying is that there are some PPV HD MPEG4 channels on 61.5 that are using QPSK.
Therefore HD receivers that dont support an 8PSK module can view those channels.
Username: Tapeman
Post Number: 3715
I got what hae says
What I'm saying they are regular SD channels
Yo can get them with any FTA receiver
Cuz they are not HD, they are SD
They are 720x480 SD MPEG-2 QPSK any FTA receiver can get them at present time
Username: Tooter
Post Number: 26
One channel is #541 HDPPV and if you scan the mentioned TP with a SD receiver the channel will be found under 'RADIO'
