Puff bin stops at around 19% flu conv
Username: Jaye50
Post Number: 135
for the last two loads my converted flu will stop at anywhere from 7% to 22% when i try to load the bins.....i've reset and changed cables....it makes no difference....the last time i kept trying over and over and it finally made it through a download.....anyone got an idea as to why??
thanx.....
Username: Nydas
Post Number: 12652
Use straight RS232 cable.
If having problems, with the receiver in "ON" status load the Jvvh_Fortec-Pansat_CanAm_(PUFF)_253_(640K).BIN or CS_253T_PUFF_BOOT_Serial_Lightning.bin
and then load the PUFF_272 BIN the normal way.
Username: Jaye50
Post Number: 136
i'll give it a shot....thanx....
Username: Jaye50
Post Number: 137
finally got it loaded....set up the sats....everything came up for about 5 mins channels played perfectly....and then it cut off.....hard reset by itself....p.u.f.f. came across the recv face....sat on f for a while like always....then shows 75 and stays there....no pic no menu.....
